20 Most Recent HP PSC 2410 All-In-One InkJet Printer Questions & Answers
4answers
Spooler service not working
try uninstalling the driver then reinstall again then check if it work
11/1/2023 4:38:34 PM • HP PSC 2410... • Answered on Nov 01, 2023
13answers
WHERE COULD I DOWNLOAD THE HP DIRECTOR SOFTWARE
Try from their official webpage, or use this Driver Update Software for XP Vista 7 8. I hope I have helped. have a nice day Ryan
11/6/2021 7:04:52 PM • HP PSC 2410... • Answered on Nov 06, 2021
5answers
Resuming operation after a power failure.
In case of Power Failures / Surges.....we should first check if the h/w of the printer has gone defective... Try the following in the specified order... 1. Unplug the power cable at the back of the printer and replug it and then press the "ON" button on the printer to check if it works else... 2. Unplug the power cable from the surge protector (if you are using one) and replug it and then press "ON" button else just try unplugging from the wall jack and replug the cable (if you are not using a surge). 3. Else , Try a different wall jack 4. You may even try taking the printer to a different room and then check if you get some power. Now if the printer powers up but the "startup cycle" continues...it needs a "semi full reset" to do that-> 5. unplug the power at the back of the printer and 6. press # and "6" at the same time on the front panel 7. while holding these two buttons , replug the power at the back and keep holding till you see "semi full reset" on the screen 8. Now release the buttons and let the reset complete...you may be prompted to enter the language again etc.... Even if this doesnot work...try a "full reset" 9. Which is done by pressing "#" and "9" simultaneously with the same procedure Else the firmware(program inside the printer) has gone bad and may need replacement A good option is to upgrade it by calling the tech support....they do hav an option to exchange your printer with a better model and you will benefit by about 40% over the price of the new printer
10/1/2018 11:14:12 AM • HP PSC 2410... • Answered on Oct 01, 2018
Hp photosmart 2410xi - paper won't feed properly through, jam
Go to an office supply store and pickup printer cleaning sheets. They are sticky on both sides. You run a sheet through it a couple of times to remove paper dust from the rollers. The pickup roller is so slick it is drawing in more that one sheet of paper. Cleaning the rollers and the paper path will solve your problem.
3/20/2017 11:00:11 PM • HP PSC 2410... • Answered on Mar 20, 2017
I need to set the scanner, how i can do it?
you can do it easily by installing the utilities from the disk.
4/9/2016 4:23:23 AM • HP PSC 2410... • Answered on Apr 09, 2016
My hp psc 4210 inkjet all in one printer,
Check the sensor of end position
3/5/2015 5:57:23 AM • HP PSC 2410... • Answered on Mar 05, 2015
0answers
0answers
What is the defination of Mission?
1. a group or committee of persons sent to a foreign country toconduct negotiations, establish relations, provide scientific andtechnical assistance, or the like. 2. the business with which such a group is charged. 3. any important task or duty that is assigned, allotted, or self-imposed: Our mission is to find the child a safe home. 4. an important goal or purpose that is accompanied by strongconviction; a calling or vocation: She has finally found her missionin life. 5. a sending or being sent for some duty or purpose.
  • 5/13/2014 5:47:39 AM • HP PSC 2410... • Answered on May 13, 2014
    My Microsoft Paint Software does not allow scan to PC
    Remove and reinstall, If you have a disk use it, if not download from HP site and install newest drivers, if using with Windows 8, some machines will not work... Remember to shut off printer and remove the usb cord if you are wiring direct, do not plug in till it tells you to...
    5/2/2014 12:00:55 PM • HP PSC 2410... • Answered on May 02, 2014
    HP PSC 2410 All-In-One InkJet Printer Logo
    747 questions posted
    k24674
    Grand Canyon Tech
    Grand Canyon Tech
    View Most Popular
    • HP Office Equipment & Supplies
    Most Popular Question
    microsoft paint software not allow scan
    • Office Equipment & Supplies
