20 Most Recent
HP OfficeJet 6110 All-In-One InkJet Printer Questions & Answers
Printer does not print whole document
In 'Print Preview' look at the margins, and see if anything is too close to the edge of the paper. If it is, then set your margins further from the edge, or drag graphics further from the edge, etc.
To correct the margins that are set to close to the edge of the paper, open the document in Microsoft Word and follow these steps:
- Make sure that you are using the same printer driver that gave you the error in Microsoft Word Viewer.
- In Word, on the File menu, click Page Setup.
- Click OK.
You receive a warning dialog box about the unprintable regions.
- Click the Fix button.
- Save and close the document.
You can now open and print the document in Word Viewer without receiving the error message.
HP Officejet 6110 "Carriage jam" error message
Get Instant services and solution for your HP Printer support. Printer services USA is here to fix your printer anywhere anytime, just call us on our toll-free printer number +1 866-918-4391 or for more visit our official website
https://www.printsupportusa.com/
Scanner failure hp 6110 - Noise and stuck head
Thanks to Silly Girl, I've got my HP6110 working again! Though to be honest, I almost gave up after trying out her suggestion by cleaning the glass and it did not work. I then removed the slider unit from the belt and realized that two of the mirrors were foggy. Again I cleaned them with a swab & windex, hooked them back up and... still the same problem. Luckily, I didn't give up. I took the whole thing apart again and this timecleaned the camera lens with a swab and it finally worked!!!
So with Silly Girl's permission... if I may paraphrase her steps and add a couple to it in case people followed her steps and still did not work.
1. Disconnect the printer from all cables.
2. Remove all the screws that hold the glass panel (you do not need to remove the one screw that's on the left hand side, in the middle).
3. Remove the plastic panel that's over the buttons just by popping it up using a knife or something similar.
4. Extract the keyboard from the inside by unhooking the lock that's on the bottom right of the keyboard (close to the center)and slide the whole board to the left.
5. Then lift the upper unit with the glass panel and place it in the back standing up.
6. You can now reach the inside of the glass and clean it with a window cleaner using a dry clean cloth.
7. While you're at it, push that slider unit to the left and lift it out; the left side of the metal rod is not screwed in.
8. Remove the black slider unit by unhooking the belt from the slider unit and gently pull out the electrical harnest cable (you might want to mark one side with a permanent marker to remember which side when you re-attached the cable).
9. Gently and carefully pop open the cap on the bottom side.
10. Once it's opened, you'll see about 4 mirrors inside and a camera lens. Dip a couple of swabs in windex and GENTLY clean and dry all mirrors and camera lens.
11. Carefully re-install everything by retracing your steps.
12. Reset unit by pressing the # and the 6 keys together while plugging in the power.
If you follow all the 12 steps, I guarantee the problem will be fixed and be just like new. Thanks again Silly Girl for the wonderful tip.
How do you preform a "hard reset" on an H.P. 6110
Hello
Do the following
1. While the printer is on remove the power from back of the printer
2. Hold # & 9 key and connect the power pin to the printer
3. Release the keys after a while
4. Printer will display full reset
You are done.
My hp scanner not working
Hi
follow this steps
1.disconect usb cable
2.uninstall your printer from your pc
3.run setup from printers cd or from the driver you can
download from Hp official site
4.follow the setup steps
5.only connecte your printer to pc when setup ask you to do
If i helped you
pls vote me
Scan to emai on HP6110 all in one printer
give it up
just take a picture of the emails with your cell phone and then email the picture to yourself or whoever and know you have a copy but honestly why anyone would need to scan emails which are already digital and on computer makes no sense at all.
this is the same as deciding you need to drink some water so you take water and freeze it into cubes then pull them out and let them thaw so you can drink it
6110xi leaves a dark line on the right 1/3 side of
Print is skewed
- The rear access door might not be fully locked into place, causing the paper to skew in the all-in-one. Remove the rear access door by pushing in on both release tabs as shown in the figure below. Inspect it for damage, and then reinsert it. Make sure it is securely latched in place.
Figure 6: Releasing the rear access door latch on one side
Figure 7: The rear access door removed
- The paper feed rollers may be dirty. Over time, paper fibers and dust will stick to the rollers and should be removed.
- Unplug the power cord from the back of the all-in-one and open the front to expose the print mechanism.
- Gently wipe the paper feed rollers with a soft clean cloth slightly dampened with clean water. These rollers may be rotated with the power unplugged.
- Remove the rear access door shown in the figure above and wipe the paper supply feed rollers. These rollers may be rotated with the power unplugged. Allow the water to dry for five minutes before reinserting the rear access door and locking it in place.
- Close the all-in-one and reinsert the power cord.
Will my hp officejet 6110 work on chromebook
Yes your hp office jet 6110 works on chrome book by following the below methods:
Method 1: Check system requirements
• Chrome book connected to the network with an active Internet connection.
• Create Google account in the latest version of chrome browser.
• The printer hardware is set up and connected Chrome book with a USB cable or wireless network.
USB connection: Make sure the cable is securely connected to the printer and to a working USB port on your Chrome book or computer.
Wireless network connection: On the printer, make sure the wireless signal is turned on and the printer is connected to your network. Make sure the printer is connected to the same network the Chrome book or computer connects to.
Method 2: Install HP Print for Chrome
1. Open the Chrome browser, and then go to the HP Print for Chrome
2. Click ADD TO CHROME.
A confirmation message displays.
Adding the HP Print for Chrome app
3. In the Add "HP Print for Chrome" window, click Add app to confirm the new app.
