20 Most Recent HP DeskJet F380 All-In-One Printer Questions & Answers
  1. Go to HP website. http://welcome.hp.com/country/us/en/support.html
  2. Insert model number.
  3. Download driver.
  4. Double click downloaded file. This will install the driver and software.
HP DeskJet F380... | Answered 3 days ago
You can call hp tech support toll free number - 1-800-585-2494 and they will give you all information regarding to your printer. for more information you can visit: HP Customer service .
Hope this will help you better.
HP DeskJet F380... | Answered on Oct 12, 2019
download driver for your particular operating system
https://support.hp.com/us-en/drivers/selfservice/hp-deskjet-1000-printer-series-j110/4066042/model/4066376
HP DeskJet F380... | Answered on Sep 24, 2019
instal my printer without the cd installer HP Deskjet 1051
HP DeskJet F380... | Answered on Aug 24, 2019
i was in HP tech support supporting AIO printer models, Just click on the link u will get a popup window to download the Driver for ur Printer.
http://snipurl.com/f380_driver_xp
HP DeskJet F380... | Answered on Jun 20, 2019
Hp deskjet f2280 pinter don't install in windows 7. now what can i do ?
HP DeskJet F380... | Answered on May 29, 2019
To get the drivers select the link below
http://www.siliconguide.com/drivers/device/617/
when you get to this website select right download for your operating system, save file and install, that easy
cheers
Brett.
HP DeskJet F380... | Answered on May 21, 2019
Go to hp.com, product support, download driver, type in your model number and go.
HP DeskJet F380... | Answered on May 07, 2019
same thing, woring one minute, next minute, offline. cords plugged in , no reason i have found but it happens all of the time
HP DeskJet F380... | Answered on Sep 12, 2018
Next page gives support for HP F380, Windows 7 32-bit:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=4062&lc=en&dlc=en&cc=us&product=1128296&lang=en
For other Operating Systems for the F380, go to next link and select the required:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1128296&lc=en&cc=us&dlc=en&lang=en&cc=us
HP DeskJet F380... | Answered on Feb 16, 2018
I had the same problem. I could print, but not scan.
However, if you open up Paint and go to file and scan, it will scan your document. For some reason, using the scan button on the printer itself will not work with Vista, but using Paint will. I also heard that using Windows fax and scan will also work.
good luck
HP DeskJet F380... | Answered on Feb 15, 2018
I lost the CD installer of my HP Deskjet F380, how I can install it?
Is it a legit HP ink cartridge? I have had a few knockoffs fail to be recognized in my printer. Seems like the printer companies are getting wise to the knock off brands
HP DeskJet F380... | Answered on Feb 12, 2018
unplug the USB lead and plug it back in...if no response try another USB port, if still no response use a different lead or put a gentle bend in the one you have to make the connection tighter....make sure the printer is on of course
HP DeskJet F380... | Answered on Feb 01, 2018
Might be scanner drivers corrupted, Reinstall the Scanner drivers again. Most probably this will work greatly You can try this no (877-690-9305) for the solution. Support For Hp Printer
HP DeskJet F380... | Answered on Jan 30, 2018
Recognition of cartridges depends on several issues. Check and clean the metal contact points on the printer cartridge slot. Use rubbing alcohol on a q-tip and pat dry. Do the same on the ink cart. Any oil/film on the contacts can interfere with the communication network of the printer. Sometimes, printers just reject cartridges, mainly if you use off brand products. Naturally HP wants you to use their cartridges! Other than that, you must use HP Software updates for the computer and also, update each HP Printers FIRMWARE. Lots of folks forget that!
HP DeskJet F380... | Answered on Jan 12, 2018
if you are using word to type the address use the tool bar to center it on the page
then when you go to print , check the preview to see where it will be printed
set the printer properties to envelope and use any old envelope to see where it prints
HP DeskJet F380... | Answered on Nov 15, 2017
HP DeskJet F380 All-In-One Printer Logo
2,555 questions posted
Clive
Clive
Ekse
Thomas F. Schneider
View Most Popular
DeskJet HP
  • DeskJet HP
Most Popular Question
hp deskjet f380 drivers
  • Office Equipment & Supplies
