Screwloose IThttps://screwlooseit.com.au > Technical
Press and hold the 0 key for 10 seconds then simultaneously press START. You will then be asked to enter a code. Type "6789" and Enter. That will put you into
Copytechnethttps://www.copytechnet.com > ... > Xerox
Dec 29, 2014 - Re: entering service mode. Press and hold the 0 key for 10 seconds then simultaneously press START. You will then be asked to enter a code. Type .
To enter service mode press the status key and enter 1087 and then 1087 again. But to login for system settings the User Name is 4000 and the Password is 4000.
Hello there if u enter the service mode and it shows and password it means that the user or the service before has activated the CE password that means that you can enter if you do not know the password. Either way you have to try to enter the default CE password that is 92729272 or 00000000 or 123456789 the first one if not change should open acess to the service mode if not you have to call the konica minolta for NVRAM reset procedure there is no other alternative.
Which operating system ?
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
type in net user username
For eg. If you want to change administrator password , type net user Administrator
It will prompt you to enter the new password.
Enter the new password and the password is changed
or
Click "Start," then select "Run." In the text box displayed, enter "control userpasswords2" and press "Enter." This opens a configuration window.
Click the user for whom you want to disable the password login.
After selecting the user, remove the check mark labeled "Users must enter a username and password to use this computer."
Click "Apply."
A dialog box will prompt you for the password.
Enter the user's password to authorize the changes and press "OK."
Reboot your Windows XP computer.
When it shows the list of user profiles, click the user whose password was disabled.
If you do remember the password, you can enter its service mode option; and make it to switch ON with its factory reset password. Here you haven't specified the brand name and model number to your TV. So, it is not possible to direct you, how to enter its service mode option. If you wish to know more, check the site linked here. http://electronicshelponline.blogspot.com/ It has details about how to enter, adjust and exit the service mode to different model TVs. Pull up previous posts there, either by its left side bar,
or view it in Timslide option.
press and hold "function", "Copy" and "3"in that order. enter password and press ok (default password is 00000000) if you see F1 your in.to get out press and hold function and clear or restart m/c
1. Press the "Function", "Copy", and "3" keys simultaneously in that order to enter the Service Mode.
2. “Input the password” to enter the Service Mode (default password is 00000000, except for C322/
C262 which do not require a password).
3. Press "7", and then “Start” keys to enter the F7 Service Mode (counter ).
4. Check the entry for the option 01 that will be you password
To recover/change the Administrator password perform the following;
1. Enter the Service mode.
2. Press STOP-0-CLEAR to enter the Enhanced security mode.
3. Enter Administrator Password setting, and enter new Password.
