20 Most Recent Konica Minolta bizhub C250 All-In-One Laser Printer Questions & Answers
what lamp error
Konica Minolta... | Answered 2 days ago
Hi this kind of errors how came u should mention frst
may ne after you removed the board and then came ?
or while working suddnetly came ?
please specify
Konica Minolta... | Answered on Feb 07, 2019
Sometimes just open the doors and closing them a few times will work its sensing somethings open ,Make sure all is closed you may have too reinstall drivers. start over read all directions sometimes we get burnt out on trying to get something going give it a break for a bit then try again. could be a firewall or anti virus cause problems to.
Konica Minolta... | Answered on Feb 05, 2019
Are you using a 3rd party image unit???, if so get OEM there are chips on them that copier monitors. The image units are the units below the toner cart. which one is having the problem Y M C or Black, did you re chip them, bad idea. Replace them with OEM cartridge.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
hi piz Error code P9 and P21 appears on screen and when printing or photocopying using color black, blank copies are outputed
Konica Minolta... | Answered on Oct 26, 2018
Most likely there is paper stuck in the very back behind one of the trays. Take both trays out and see if there is any paper jammed (could be a small piece). Put trays back in but leave them open, turn off the printer, unplug it, wait 5 minutes, plug it back in, turn it back on and push in the trays.
Konica Minolta... | Answered on Sep 24, 2018
machine trouble sevice call [c2558] wat a problam in konica minolta bizhub 164 printer
Konica Minolta... | Answered on Jul 08, 2018
It is a fuser error.
Try resetting. To reset a Rank A error follow these steps:
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
If the error recurrs then do the following:
1 Check the Fusing Unit for correct installation (whether it is secured in position).
2 Check the Fusing Unit, PWB-M and PU1 for proper connection and correct or change as necessary.
3 Change Fusing Unit
4 Change PWB-M
5 Change PU1
Konica Minolta... | Answered on Jun 26, 2018
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
Konica Minolta... | Answered on Jun 22, 2018
Does this happen when copying? Can you print internal copier form meter count etc.?
Konica Minolta... | Answered on Jun 20, 2018
Hope this helps. Make sure you remove the waste tank prior to taking out the transfer belt. Belt is removed by two screws inside right door and sliding the unit out.
Konica Minolta... | Answered on Jun 14, 2018
2. Turn Main Power Switch ON while pressing the Utility/Counter key. (Sub power must be "on" located on side of the control panel)
There is no procedure to restore the admin password. It is possible to reset and enter a new password, and for that you will need a technician to make the adjustments on SERVICE MODE (stop,0,C).
Konica Minolta... | Answered on May 18, 2018
no such code for a C250
Konica Minolta... | Answered on Mar 25, 2018
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Reset key.
4. Check to make sure that [OK] is displayed and it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Its looking for the fax board ??? Some one remove it????
NVRAM error when the main board was replaced was the NVRAM module replace was this a new board or one from a different machine if so you machine is junk. Have tech come out to re-flash firmware get a new board etc if he can
Konica Minolta... | Answered on Mar 18, 2018
the control board can not talk to the hard drive was the hard drive replaced?
see the previous post sir mam
You must have access to the a secure KonicaMinolta web site, need a tech to come out
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
1,250 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
George Mclaughlin
Clive
Clive
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
bizhub Konica Minolta
  • bizhub Konica Minolta
Most Popular Question
clear error message c 2558 konica
  • Office Equipment & Supplies
