20 Most Recent
Dell Dimension 5100 (D51L1) PC Desktop Questions & Answers
VLC DVD player is jerky
What are your PC specs for RAM and CPU speed? VLC player is an amazing player. Are you saying this player is jerky on the same videos that another player was NOT jerky on? That seems very odd. I have yet to experience a jerky playback on VLC for movies (mostly HD).
Is your PC doing something else in the background while attempting to play the movies? Hit Control, Shift, Escape while playing a movie and look on the bottom at how much CPU % the PC uses before and during movie playback.
Print size on AOL email is too small
Follow these instructions to change your font size.1. Sign on to AOL and visit AOL Keyword: Preferences.2. On AOL , click Font & Text Settings. On older versions of AOL, click Font, Text & Graphics.3. Under the Font Preferences heading, select your preferred font, text size and color for writing email, Instant Messages and chat.4. Under the Text Preferences heading, select your preferred size for viewing text from other people: Small, Medium or Large.5. Click Save.
Vista stuck in update loop
F8 at power-on, Safe Mode, then go looking for the 'autorun' entry (launch 'msconfig' from a 'DOS box' (aka 'Command Prompt')
NB. For a long-term solution, I suggest you upgrade from Vista to Windows XP ...
Dell desktop computer wont turn on
Hello, make sure there is a green light on the front of the monitor, if not then no connection from pc to monitor, Make sure monitor is plugged in and powered up, and cable is connected into the pc. If all this is connected, then you either have bad video card, or motherboard for video or bad monitor.
Dell studio one 1909 cd eject
Hello, There is a pin hole on the front of the cd player, straighten out a paper clip and stick in the hole and push to open the cd door, you can do this without powering up the pc.
Please rate the answer, thank you.
Can't get 1600x900 Resolution
Your graphics card may not be able to display this screen resolution.Open Control Panel - Display - Settings tab and move the slider on the Screen resolution - to get as close to 1800 X 900 then click apply.
What is system password
Hi
I presume that you are referring to the computer system password that is required before you even get to the Windows start up screen.
In this case it is easier for you to download the manual by going here:
Product Support Dell US
and clicking on the "PDF" link beside the Service Manual. You might find it handy to save the manual to your computer for future reference.
There are two sets of jumpers on the motherboard relating to your problem, they are the Password jumper "PSWD" and the RTC reset jumper "RTCRST". They can both be located on the diagram of the motherboard on page 75. The RTCRST is near the battery, and the PSWD is near the Speaker and CPU fan connector.
The PSWD jumper should be set on pins 2 & 3 to disable password features. (See page 90)
The RTCRST jumper should be transferred from pins 2 & 3,and put on pins 1 & 2. After about 5-10 secs this should be replaced on pins 2 & 3. (see page 85)
Hope this is helpful, if so would you please register that with Fixya
Cheers
How to eject cd from dell all in one computer
If the eject button is not working, go to Start and then my computer (Win XP) or Computer (Win 7) you should then see the drive, right click on the drive and click the Eject option.
Should that fail you may need to eject it manualy, check the drive door and you should see a small hole, use a paper clip or similar and gently press it in to the hole. This should release the lock and let you open the door.
When i turn On my PC this thing shows in the monitor. <300 XT BIOS P/N 113-A33437-102
Open the case, loosen the 2 screws holding the
black plastic casingon the cooling tower over the
CPU. Carefully remove, or tilt back to reveal cooling tower radiator and coil.
If there is a layer of dust built up (like there was on mine); carefully vacuum clean the radiator, cooling tower unit, fan and all other surrounding areas. Clean any residue from tower-to-CPU contact area.
Vacuum entire PC inside and out. Remove, reseat, vacuum video card. Reseat storage drive cables reseat the memory sticks, close it up and plug it back in start computer.
