20 Most Recent
Konica Minolta bizhub 350 All-In-One Laser Printer Questions & Answers
SC46-08
An abnormal speed signal of the paper feed motor (M4) is checked. An error detection signal is detected twice in succession
ERROR CODE C0096 - BIZHUB C350
2.6.19 C0096: Image Transfer Belt pressure/retraction failure
2.6.20 C0098: Fusing Pressure Roller pressure/retraction failure
Relevant Electrical Parts
1st Image Transfer Retraction Position Sensor (PC12)
1st Image Transfer Pressure/Retraction Motor (M11)
Control Board (PWB-MC)
Step Action
WIRING DIAGRAM
Control Signal
Location
(Electrical
Component)
Check the M11 connector for proper connection
and correct as necessary.
2 PC12 I/O check PWB-MC PJ3MC-6B (ON) 6-B
M11 operation check PWB-MC PJ5MC-1~4
(Pulse Output)
6-C
4 Change PWB-MC
How to find the MAC address for a konica minolta
I know this is and old post, but I came across this issue today and this post is the first that came up in my Google searches, and three was no good response. So I thought I would post an update.[Sorry Zaheer, I know you were trying to be helpful, but your response was a little too vague and in the end, inaccurate]1) Go to the printer's Web Connection by typing the IP address in a browser. 2) Make sure you are on the "System" tab (Blue) at the top3) Click on the "Detail" link on the side menu4) Click on the "Interface Info" sub link* Notice that you do NOT log into the Admin portion of the Web Connection. That will only confuse you.This will show various stats, one of which is the MAC Address of the machine. It seems like this would be better placed in the Network tab under the admin interface, but here it is.Hope this helps someone.
Print a report
Pess utility printer setting print report and then print what you want
How do I get my
First u need check your USB CABLE or USB connector is working or not
RESET TRANSFER BELT BIZHUB C350
A new belt will have to be installed at which time the fuse in the new belt will be blown to start a new count from 0. Now you can replace the fuse in the old one if you know how.
