Suction fan motor malfunction power off the on wait ten seconds between. check all the vents on the machine remove the covers where they are located and power on the machine check to see if they turn use can air to clean or get them replaced.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: how to fix error c-1183
This code is for a bin/tray raising or lowering failure in the finisher. This can be caused by either the trays not being fully inserted into the finisher or something stropped the bins from raising or lowering. Check the trays and make sure they are as close to the finisher/fully installed as possible. Then turn off then back on the main power switch (NOT the stand by one on the control panel)
You should see the bins raising and lowering into their home position.
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Now, the malfunction error code is solved by replacing "Fan Motor" of the machine. The Fan was jammed due to which it was not functioning.
