Replace the developer and the drum make sure counters are cleared first and that Gradation adj is run along with Toner adj Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Replace toner cartridge or did you fill it your self, if there is a chip on the cartridge and you refill your self then the old cartridge is still old. Are you using 3rd party or OEM? replace with oem Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
some cartridge have electronic chips on them if the chip says empty then the copier say ok replace the toner will not tell the chip it is new Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
no is that cartridge third party????????????or OEM, use OEM most have chips on them to tell when used up Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
The toner cartridges have electronic chips on them that tell the copier when they are used up since all you did was refill the cart and did nothing with the chip then copier still sees a used cart get a OEM cartridge install it correctly Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Most toner cart have chips so filling is not going to work that how the printer knows it has a new cartridge installed Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
