Power off the machine. Then remove the toner bottle, be careful the hole might be on the bottom and the toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner bottle correctly. If that does not work, you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad.
Does it say image unit or drum????????
SOURCE: service manual for KONICA MINOLTA Bizhub 210/162
Swithc off the machine Press stop button and hold switch on the machine. problem will go.
Good Luck
SOURCE: After a power surge it comes up with a C0501 malfunction code and shuts itself down
Turn ON the Power Switch with the Stop key held down. This also works on bizhub 162
SOURCE: canon Ir2018 always indicating ''no toner, change toner''
Because you need to clean and shake the toner unit. When you say " ive been fixing" does it mean that you now what you are doing or?
If yes dismantle the toner unit and vacume it, it may be that toner stucked on "antena" for toner recognitions.
If not - call service
Pls. rate
SOURCE: Konica Minolta bizhub 163 Display
Code M2 means your photocopier machine require maintenance.In maintenance some old parts of your machine will be replaced with the new one and all this will be performed by technical services representative.
Konika Minolta BizHub 163 - Error Code M2
Press the Utility button,
then Stop 0 0
then press again Stop 0 1
then scroll to Clear Data, and then Supplies Data and clear.
You must be aware that clearing this counter clears the drum, developer and other counters.
