20 Most Recent
Sharp AR-5316 Advanced Digital Imager Copier Questions & Answers
We are trying to connect the Desk top PC so as to
you may gey the driver software for AR=5316 printer install sotware inthese websites
http://nodevice.in/driver/AR-5316/get47086.html
http://ptf.com/sharp/sharp+ar+5316+printer+drivers+to+support+windos+7/
We brought sharp ar-5316 oneyear
How was your day, hope fine. Sharp Ar5316 driver are for windows. This means that the printer drivers are only compatible with windows and not with linux. My advice to you is that please uninstall Linux system from your desktop and servers and install windowsxp instead and your copier will work. Remember to save important files while doing this as they may be lost in the process. Let me know your progress.
Reset counter of sharp ar-5316
How to reset meter reading counter;
a. in the operation panel ,press * ,interrupt, CA, interrupt keys.Display must go off.
b. enter 84 and press copy key. 000,000 will flash in the display
The copier meter reading is now reset to 0.
START PROBLEM
U2 Counter sum check error When the counter check sum value stored in the EEPROM is abnormal
Enter sequence...clear, interrupt, 0, interrupt. The copier will
go off. While off enter 16 and Start. Your copier will come back on. press Clear All.
may need a new cartridge as chip may be broken if this does not work
SHARP AR5316 ERROR CODE F2
1- replace the toner cartridge.2- replace the chip toner cartridge.3- check and fix connection between toner cartridge and mcu pwb.
My sharp ar5316e is showing
That indication is Toner Indication.You should change the toner,Now May be the toner chip also damaged. whether the machine worked after changing the toner then no need to change the toner chip,other wise the same indication still, then you change that one also.
Get F2-40 error on sharp ar-5520 Im a newbie in
How are you , this problem occurs when there is very low toner concentration on the unit or low developer.
solution
- Replace a toner cartridge and make sure it is smoothly running as some come with hardened toner or
- Replace a new developer which is Sharp Ar 205 dv Check that the toner motor is rotating well
This error is self resetting so no need of simulation code. Bye.
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Code error h2
Hi
Error code H2 means fusing unit temperature error. This error occurs due to a bad fuser temperature thermistor or due to fusing lamp. To resolve this error try and reset the unit by entering the service mode--
press # - INTERRUPT - C - INTERRUPTthen14start
If this resolves your issue then try restarting the printer and try the reset again. However, if reset is not helping you then you
