Don't they come with coax and antennas already installed? If you can run the coax out the window to the mirror bracket then up and over the visorsthat would be good.the only thing is if it has a fiberglass door,no ground plane. you will have to then ground the antennas to the chassis and maybe even use a grounding strap.
SOURCE: how to replace cb coax peterbilt model 335
take the old out pay good attention to the way it comes out so you can put new back in
Yes coax already run but dried rotted need to run new one
when you pull the old one out pay attention to the way you remove it then just run the new coax the same way .
