20 Most Recent Cobra 29 WX NW ST 40-Channels Base CB Radio Questions & Answers
2answers
Need wiring diagram for plug for 12vdc cobra 29 nw
Hello awchris.
Welcome to FixYa.
My name is John, and I will be assisting you with your issue today.
With your unit face-up, you will have three (3) pins in the back, the
positive (+) is the pin on the end closest to the next pin. the negative (-)
pin is the one that,s further away from the others. You can purchase this
plug at any CB shack or RADIO SHACK for a few bucks.
I hope this was helpful to you. Your Comments and Testimony,s are always
welcomed here and thanks for choosing FixYa today and in the future.
1/11/2023 12:13:33 AM • Cobra 29 WX NW... • Answered on Jan 11, 2023
2answers
Cb is Keying Down instead of keying up when trying to talk
if you are transmitting fine Don't worry about the meter. Get an external SWR meter, they are better anyway.
Also, make sure the the switch next to the meter is all the way up on s/rf setting. thats for signal power and receive strength.
8/2/2022 8:19:23 AM • Cobra 29 WX NW... • Answered on Aug 02, 2022
What is the best way to run cb coax in a 2006 peterbilt 379
don't they come with coax and antennas already installed? If you can run the coax out the window to the mirror bracket then up and over the visorsthat would be good.the only thing is if it has a fiberglass door,no ground plane. you will have to then ground the antennas to the chassis and maybe even use a grounding strap.
10/10/2019 5:18:25 PM • Cobra 29 WX NW... • Answered on Oct 10, 2019
When turn on its stock in transmits
I hate when something is stock. Try Cobra here: Support Cobra Electronics Corporation easy-4xcgpgmbsyetxdvhu0rk3j02-5-0_12.png awesome-4xcgpgmbsyetxdvhu0rk3j02-5-2_8.png
2/4/2018 6:27:07 AM • Cobra 29 WX NW... • Answered on Feb 04, 2018
NEEDLE MOVES ON RECIEVE LIGHT BURNT OUT AND NEEDLE DOES NOT MOVE ON TRANSMIT IN S/RF,SWR OR CALIBRATE BUT RADIO TRANSMITS GREAT..
try blowing some canned air on the knob and switch to remove dust , also try a dash of electrical component spray on them , then see if it works.
5/21/2015 5:09:45 PM • Cobra 29 WX NW... • Answered on May 21, 2015
2answers
The weather channels quit working on my cobra 29 nightwatch.
its an internal problem , take it to a tech and let them fix it. the board for the wx probably has jumped freq. and thats why you can't receive wx.
4/15/2015 6:56:55 PM • Cobra 29 WX NW... • Answered on Apr 15, 2015
What are the settings on a cobra 29wx nw st
same as the 29 ltd classic .
3/1/2015 8:21:24 PM • Cobra 29 WX NW... • Answered on Mar 01, 2015
I have a cobra 29 ltd classic it is receiving fine
check the final,it may be on it way out.
2/15/2015 11:38:57 PM • Cobra 29 WX NW... • Answered on Feb 15, 2015
I am looking for the
google it . its there , I checked.
2/15/2015 11:18:52 PM • Cobra 29 WX NW... • Answered on Feb 15, 2015
0answers
Trying to connect bluetooth to
google it
12/22/2014 1:03:48 AM • Cobra 29 WX NW... • Answered on Dec 22, 2014
I have a cobra 29 wx nw st withwilson little wil
first of all you are going about it wrong. To set your SWR you check it on channels 1 , 19 , and 40. If you reading is higher on 1 than on 40 you have to shorten your antenna . if its higher on 40 than on 1 then you have to lengthen it. before you do any adjustments to it ,loosen the set screws and let the antenna fall to the bottom then bring it up 1/4 " and tighten the screws. You should also use an external SWR meter not the one on the radio. Thats good for making checks every once and a while. With the meter you key the mic and have the needle go to set then put it on for and key the mic to obtain you reading . Anything under a two is good .
12/22/2014 12:55:40 AM • Cobra 29 WX NW... • Answered on Dec 22, 2014
Cobra 29 refuses to calibrate
Check for a short in the Coax. Is the antenna near the cab of a truck or other body part? Is the antenna grounded? Has your radio been peeked and tuned?
11/26/2014 12:17:11 AM • Cobra 29 WX NW... • Answered on Nov 26, 2014
I cannot get my swr meter to calibrate to check swr. My radio has been tuned and peaked. I have 18ft of coax, and I have run extra grounds to the antenna and the radio. Why can't I get it to calib
where do you have it mounted?Is the antenna an adjustable one with set screws? You may have to move the antenna up and down to get a good match. Anything under a 2.0 is good.
11/25/2014 9:33:02 PM • Cobra 29 WX NW... • Answered on Nov 25, 2014
Turning up the modulation in a cobra 29 wx radio
vr4 is it
11/25/2014 8:37:56 PM • Cobra 29 WX NW... • Answered on Nov 25, 2014
Cobra 29 wx nw st how to increment modulation
Clip D-11 .diode 11 .this is the modulation limiter .
10/18/2014 6:20:11 AM • Cobra 29 WX NW... • Answered on Oct 18, 2014
How do i set up my cobra 29lyd
get any cb owners manual ,Look up how to install and do it.
10/4/2014 8:10:35 PM • Cobra 29 WX NW... • Answered on Oct 04, 2014
I have no reaction from channels 1 thru 22.
sounds like the radio is out of alignment or the pll has failed. have the radio serviced
9/14/2014 8:11:11 PM • Cobra 29 WX NW... • Answered on Sep 14, 2014
Adjust modulation pot
vr4
9/1/2014 3:34:23 PM • Cobra 29 WX NW... • Answered on Sep 01, 2014
Does my cobra 29 wx nw sound tracker cb radio have internal fuses
If you have reversed power leads you may have blow the protection diode and fuse. Well I am sure the fuse is blown if this is the case you may have been lucky and only popped the fuse if you replace the fuse an it blows also you will know for sure but be sure you don't use a larger fuse. Now we will assume the worst that the diode is blow. Remove the speaker side cover and with a pair of side cutting wire cutters cut D23. If you have trouble finding it its the second component from speaker jack next to a cylinder electrolytic capacitor it is a black component. This will stop your fuse blowing problem that was created when reversing polarity but unless you replace the diode you have disabled your protection if it happens again. It is a good practice to turn on/off switch to off position before connecting power. Take care .....hope this was of help.
7/28/2014 9:38:07 AM • Cobra 29 WX NW... • Answered on Jul 28, 2014
Cobra 29 WX NW ST 40-Channels Base CB Radio Logo
142 questions posted
Top Cobra Radio Communications Experts
Mike Cairns
Mike Cairns
eradiostore
eradiostore
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Cobra Radio Communications
Most Popular Question
weather channels quit working cobra 29
  • Radio Communications
