20 Most Recent Cobra 19 DX IV CB Radio Questions & Answers
My Squelch on my Cobra
It means either the knob or something in the squelch circuit has gone bad. Doesn't mean that you cannot use the radio, you will just hear static all the time when no one is talking. If the static bothers you, you can always back the RF gain down a bit. That will quiet the noise, but lower you receive range. meaning you won't hear as far away.
10/7/2019 3:25:17 PM • Cobra 19 DX IV... • Answered on Oct 07, 2019
manual
2answers
Can you adjust a 'rubber duck' antenna? I have a
Sorry, but each rubber duckie is cut to a specific frequency, with the actual antenna windings sealed inside the rubber/plastic outer shell. Because of this construction, there is no adjustment feature.
3/3/2017 9:01:36 PM • Cobra 19 DX IV... • Answered on Mar 03, 2017
How to peak and tune Cobra 19 DX IV
L 5 , L 6 , L 801 for power and RV2 for modulation.
9/13/2015 10:02:51 PM • Cobra 19 DX IV... • Answered on Sep 13, 2015
MI RADIO COBRA 19 SALE POBRE PERO RECIBE AL 100
$2.00 US
9/13/2015 9:54:10 PM • Cobra 19 DX IV... • Answered on Sep 13, 2015
No tengo TX
I realize it may be difficult but you should at least have some else write out your request in english.
9/8/2015 12:51:00 PM • Cobra 19 DX IV... • Answered on Sep 08, 2015
2answers
It recieves and shows its
check the radio out by listening to another radio at the same time you talk on yours .
3/5/2015 11:10:10 PM • Cobra 19 DX IV... • Answered on Mar 05, 2015
Need more power
not impossable but if you have to ask then you are not qualified to do it.
2/16/2015 1:20:44 AM • Cobra 19 DX IV... • Answered on Feb 16, 2015
Cobra 19/dx4
pfm00103ba
2/15/2015 11:15:26 PM • Cobra 19 DX IV... • Answered on Feb 15, 2015
I have a cobra radio
you should have check to see if one transmitted and the other received before you did all this then there would be no problem of this nature . Its probably not the IC but a resister or a diode.
12/22/2014 12:29:48 AM • Cobra 19 DX IV... • Answered on Dec 22, 2014
No led display and audio
gee did you check the reverse polarity diode
12/21/2014 11:37:15 PM • Cobra 19 DX IV... • Answered on Dec 21, 2014
Where is dev pot located Cobra 19dx
its factory set for a reason. being you could be interfearing with someone talking down in the 10 meter band or lower.
12/18/2014 10:41:34 PM • Cobra 19 DX IV... • Answered on Dec 18, 2014
Where the modulation pot in a cobra 19 dx iv cb
rvm-1
12/17/2014 8:55:56 PM • Cobra 19 DX IV... • Answered on Dec 17, 2014
MI CB COBRA DX-19 IV when someone ear me say i don t ear you well sounds like bad voice or no good my voice..
try turning you radio power down to 1 watt and see what that does .the asskicker 100 watts is being overdriven by the radio power and its coming out sounding horrorable . How many watts does the radio put out now? the lower the better like I said in the begining 1 watt is best with a box.
12/17/2014 8:36:10 PM • Cobra 19 DX IV... • Answered on Dec 17, 2014
2answers
When Mic is keyed TX illuminates but no green nand
Get a SWR-PWR meter to put on the line between the radio and antenna to see what it is doing.
12/2/2014 11:33:33 PM • Cobra 19 DX IV... • Answered on Dec 02, 2014
How to internally increase modultion on cobra 19 dx 4
vr 1D
12/1/2014 12:21:14 PM • Cobra 19 DX IV... • Answered on Dec 01, 2014
How do you used swr meter
The SWR meter on the radio is some what accurate, you might want to use an external meter. First thing you do is get a pencil and paper to write down the readings. On your meter you will notice it says FWD and REF. Set your radio on channel one then set your meter on FWD , key your mic , adjust the meter to the check line , then switch it to REF and do the same . Now write this number down. Switch to channel 40 and do the same then do the same on 19.If you have a final reading of 1.5 over the band then you are ok but if its higher on 40 then on 1 you have to shorten the antenna , if its higher on 1 then you have to lengthen it . Continue this until you have a satisfactory reading.
12/1/2014 12:18:12 PM • Cobra 19 DX IV... • Answered on Dec 01, 2014
How to modify a cobra 19 dx IV
you can;t
12/1/2014 12:04:33 PM • Cobra 19 DX IV... • Answered on Dec 01, 2014
How to ground a wilson little wil cb antenna for indoor use
not a good idea
11/25/2014 9:43:46 PM • Cobra 19 DX IV... • Answered on Nov 25, 2014
Cobra 19 DX IV CB Radio Logo
114 questions posted
Top Cobra Radio Communications Experts
Mike Cairns
Mike Cairns
eradiostore
eradiostore
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Cobra Radio Communications
Most Popular Question
cobra 19dxiv working fine little
  • Radio Communications
