20 Most Recent Cobra 29 Lx Full-featured Cb Radio Questions & Answers
2answers
How do i peak and tune a cobra 29 lx
pay and get it done right so the radio does not get destroyed.
1/17/2019 4:49:39 AM • Cobra 29 Lx... • Answered on Jan 17, 2019
Have a new cobra 29lx. Everthing works fine except for the SWR meter. Can't use the meter to adjust SWR. No matter what I do the meter stays the same. Sent to factory but they said nothing was wro
i think it could be with the coax.try replacing the coax and the antenna and see what you get. make sure the antenna is adjustable with set screws.
11/25/2014 9:06:56 PM • Cobra 29 Lx... • Answered on Nov 25, 2014
How to fix cobra 29 lx that will receive but not transmit?
your final could be blown,thus no transmit . if you change it make sure you change the driver also and retune that portion of the radio.
11/25/2014 8:28:34 PM • Cobra 29 Lx... • Answered on Nov 25, 2014
Cobra 29 Lx turn power up
one of the few radios that won't allow you to turn up. the most you will get is 4.5 watts . if you want power buy yourself a 250 watt liner amp and leave the radio where it is . turn VR 4 up for max modulation and go for it.
11/25/2014 7:35:03 PM • Cobra 29 Lx... • Answered on Nov 25, 2014
My swr meter needle does not go all the way far
variable inside radio not letting you.turn up the variable and the needle should come up also check out vr 1 and set it for s-9 reading you may also try after to turn vr 2 and vr3 just a bit on both.
11/2/2014 10:17:57 PM • Cobra 29 Lx... • Answered on Nov 02, 2014
J'ai un nouveau stryker sr 89 mc comment ajuster le squege
you cannot adjust the squelch without haveing a signal generator.Si vous plait.
9/11/2014 7:52:57 PM • Cobra 29 Lx... • Answered on Sep 11, 2014
My cobra 29 lx is saying that my rf gain power failed why is that
you may have burnt the diode that a variable controls or you messed with it and burnt it out.
8/23/2014 10:42:33 PM • Cobra 29 Lx... • Answered on Aug 23, 2014
My cobra 29lx said my ptt has fail what can i do to fixs it
try a different mic.don't use a power mic,then use one see what happens then.
7/30/2014 6:20:37 PM • Cobra 29 Lx... • Answered on Jul 30, 2014
My cobra 29lx said my ptt fail when i do the radio chack on my radio what is worng with it
could be low modulation,low power,bad final any number of reasons. Look for it and you will find it.
7/30/2014 6:18:44 PM • Cobra 29 Lx... • Answered on Jul 30, 2014
How do i repair finals in cobra 29 lx
first of all are you sure its a bad antenna. I can key the mic with no antenna hooked up and nothing will happen the the finals but you may key it down with a brand new antenna and burn them also.Lokk and see how they are connected in the radio before you take it out and replace it the same way.You may want to replace your driver also.
7/23/2014 7:07:39 PM • Cobra 29 Lx... • Answered on Jul 23, 2014
CB Antenna Warning Light
Sounds like bad SWR. Check antenna ground. If mag mount, make sure mag and whe you put it is very clean. Check antenna where whip comes in to coil or base. Check pl259 with vom for continuity, open or shorts. This will probably solve the problem. DO NOT TRANSMIT WITH HIGH SWR. YOU CAN BURN OUT POWER TRANSISTOR. HOPE IT HELPS. Tom
4/27/2014 3:03:01 AM • Cobra 29 Lx... • Answered on Apr 27, 2014
No power
There are plenty of places to run the ground wire to the board. The majority of the wide traces are ground traces. This can be repaired but you must know what is and is not a ground trace and how to connect broken traces if necessary. This is serious business when you talk about repairing the voltage input so be sure or get help if you don't know for certain what you are doing.
11/17/2013 5:41:32 AM • Cobra 29 Lx... • Answered on Nov 17, 2013
The SWR cannot be changed by rotating this knob. The SWR function allows you to determine the SWR or "match" of the antenna system and transmitter on a specific channel. The entire process must be performed whenever you want to know what the SWR is on a different channel. The SWR/CAL button toggles the meter between the CALIBRATE and SWR modes. Set the radio to CH1. Press the SWR/CAL button. The radio CAL(ibrate) mode is now selected. Press and hold the mic PTT (or push to talk) button. Rotate the SWR knob as needed to adjust the meter indicator until it is on the SET mark on the dial. The meter is now calibrated for this channel.While still holding down the mic PTT, press and release the S/RF SWR CAL button to the SWR setting to read the SWR on the meter.This entire process should be done for Ch 20 and Ch 40. You must go through the CAL procedure for EACH channel before attempting to read the SWR.Changing the SWR requires that the antenna be lengthened or shortened until such time that the SWR can be reduced no further. Typical SWR across the band may be:CH1 - 1.5:1, CH20 - 1.1:1, CH40 1.5:1orCH1 - 2.2:1, CH20 - 1.7:1, CH40 2.3:1 The "dip" in SWR on CH20 is typical, as the antenna is the perfect length on only one channel - it will be come slightly too long or slightly too short as you tune up or down from CH20. The further away from CH20 you go, the poorer the SWR will be. You can "slide" the dip to any channel you prefer - say CH8. If you tune for lowest SWR on CH8, You might see CH1 with a 1.2:1 SWR, CH8 at 1.1:1 SWR and CH40 at 2.5:1. All are acceptable - sort of. Many manufacturers say up to 2.5:1 or even 3.0:1 matches are ok, There's no reason a quality antenna can't be tuned for optimum SWR in the middle of the band (CH20) to have less than a 2.0:1 SWR on CH1 or CH40, unless there is a ground issues or bad cable / antenna / connection somewhere. You can view the manual here. I hope this helps & good luck!
12/3/2012 10:15:09 PM • Cobra 29 Lx... • Answered on Dec 03, 2012
I have a Cobra classic 29zLtd.. When you key the mic needle moves a little to the right. When ur close to someone they can hear you when a few links apart they can't .
A manual link is at the bottom of this entry. Troubleshoot the problems you've described: Meter Not Working: The needle moving slightly to the right when you key the mic could be due to incorrect calibration. Make sure to recalibrate the meter according to the manual instructions. If you calibrated it differently, that might cause the needle to go against the right side of the meter. Recalibrating the meter should resolve this issue. Meter Light Problems: If the meter light isn't working, consider replacing the LED. Sometimes, a burnt signal meter light can occur. Replacing the LED should fix this. SWR Meter Not Working: Incorrect SWR calibration or bumping the calibrated knob might cause the SWR meter to malfunction. To check the SWR meter: Turn on the SWR calibrate knob until it keys up all the way at the end. Switch to SWR mode and key the mic. If the needle barely moves, turn down the Dynamike knob. Finally, switch back to S/RF mode. No Receiving Audio: If you're not receiving audio, check the following: Ensure the squelch knob is adjusted correctly. Start with the knob counterclockwise and turn it slowly clockwise until white noise stops. Verify that the microphone is working properly. You can try a different mic to rule out any mic-related issues. Make sure the radio is on the correct channel for transmitting and receiving. ========================================== Calibrating the SWR (Standing Wave Ratio) meter on your Cobra Classic 29zLtd CB radio is essential for optimal antenna performance. Follow these steps to calibrate it properly: Prepare the Setup: Park your vehicle at least 20 feet away from trees and buildings. Close all doors, hood, and trunk. Choose the Channel: Select the channel you want to check. It's recommended to test on channels 1, 20, and 40. SWR Calibration: On the radio, press the SWR/CAL button until the display shows "CAL." While pressing the transmit button on the microphone, turn the SWR CAL knob (the last knob on the right) until the meter needle aligns with the "CAL" mark. Release the transmit button. Switch to SWR Mode: Push the SWR/CAL button again until the display shows "SWR." Read the SWR: Press the transmit button on the microphone. Observe the SWR reading on the top scale of the meter. Ideally, the SWR should be below 3. Lower values are better. Remember that SWR is a measure of antenna performance, and poor SWR can be caused by the antenna, antenna cable, or installation. Adjust the antenna length to achieve similar SWR readings on channels 1 and 40 while keeping it below 3. Most antennas are adjustable; refer to the manufacturer's instructions for specific adjustments. cobra-29ltdclassic-cb-radio-user-manual.pdf (roadtrucker.com) MANUAL
4/18/2024 7:37:10 PM • Cobra Radio... • Answered on Apr 18, 2024
Cobra RX385 Two-Way Radio. Why does my walkie-talkie send messages but can't receive any sound.
Question edited for clarity and translated into 'Adult'. Question moved from Cellphone category. https://www.google.com/search?q=cobra+rx385+no+audio https://www.google.com/search?q=Cobra+rx385 ..
1/1/2024 9:42:37 PM • Cobra Radio... • Answered on Jan 01, 2024
I have a Cobra 148 GTL side mike jack.
There appears to be help here and that forum is the best place to ask. It is a Post Factory modification according to this.
WTB cobra 148 gtl side mic
WorldwideDX Radio Forum https://www.worldwidedx.com > threads > wtb-cobra-... Feb 27, 2019 - 148 GTL side-mic uses 5 pin mic receptacle. If the radio in question is a side mic and has a 4-pin receptacle, then it was put in post-factory ... Cobra 148 GTL Malaysia.. side mic?? Should I buy? Aug 13, 2018 148gtl blown d44 and mic Jack conversion - WorldwideDX Mar 1, 2018 Old school Cobra 148GTL.... ' WorldwideDX Radio Forum May 13, 2019 Cobra 148gtl Basket case! ' WorldwideDX Radio Forum May 7, 2018 More results from www.worldwidedx.com https://www.google.com/search?q=Cobra+148+GTL+side+mike+jack ..
12/3/2023 5:48:29 PM • Cobra Radio... • Answered on Dec 03, 2023
6 wires d-104 white shield blue black red & yellow what color goes to what number 5 pin cobra mobile 148 gtl
Here are the instructions:
  • PIN #1 ~ WHITE
  • PIN #2 ~ SHIELD
  • PIN #3 ~ BLACK
  • PIN #4 ~ BLUE
  • PIN #5 ~ RED YELLOW N/C
I hope this helps!
10/29/2023 6:57:32 AM • Cobra Radio... • Answered on Oct 29, 2023
2answers
I have a Cobra Microtalk walkie talkie, one sends & receives, the other just receives it won't transmit just makes loud noise. What is happening?
8/16/2023 11:51:42 AM • Cobra Radio... • Answered on Aug 16, 2023
Cobra 29 Lx Full-featured Cb Radio Logo
13 questions posted
Top Cobra Radio Communications Experts
Mike Cairns
Mike Cairns
eradiostore
eradiostore
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Cobra Radio Communications
Most Popular Question
peak tune cobra 29 lx
  • Radio Communications
