Getting error code C-0210. What's that mean? Is it a field-serviceable thing, or should we call a tech?
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
SOURCE: Minolta Bizhub C353 fails scan to emails
Hi mmarsh1212,
When you say the bizhub fails Authorization, do you menat it fails Athentication?
If so, and I pressume your technician knows what he's doing, you have an issue with a password. I suggest you create an address for the bizhub on your email server and then re-setup the scanning to email credentials via the web browser direct to the machine.
Let me know if you need help with doing this.
Regards
Taminol
SOURCE: Minolta Copier
The malfunction code is for a
Polygon Motor malfunction. The motor that shoots the laser beam across the drum
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: KONICA MINOLTA BIZHUB C350 WITH ERROR CODE C0960
Check your bypass tray, the tray is on the right side of the machine, the tray flips out for legal and 11x17 paper sizes. Check that there is nothing jamed inside, code says that the tray can't lift. so check for anything jamed inside down there. As to reset the code open then close the front door where you put the toner. Turning the machine on and off will not reset the code. but open and closing the front door will clear about 80% of the service codes.
SOURCE: what does code 2454 mean on the konica minolta
Developing motor for the Black, working in conjunction with Toner Control Sensor.
