20 Most Recent
Konica Minolta Minolta Bizhub C353 Copier Questions & Answers
Error code c5102
take each of the image units out not toner image units. Then shake each unit along its axis to spread the developer in side each one along the whole image unit. then reinstall. next pull out the transfer belt and reinstall properly. if this does not work you might have and burned out main motor or worse the control board that controls it is bad. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
Konica minolta C353 delete job history
If you're not the admin then you can't have access to the job history delete options but note that job history only keep records of jobs done not save the actual jobs done. Jobs can only be saved into the box and accessed from there.
"tray 1 cannnot be use currently " bizhub c-353
Utility/counter, touch details, stop00 stop01, touch system one, trouble isolate, select draw #1. set to unset. Turn main power off. wait 10 seconds, power on, go back in same procedure this time set to set. Power off again wait 10 seconds power on. ENSURE THER IS NO PAPER STUCK BEHIND THE TRAY FIRST, if this does not work get a qualified tech to look the problem Btw, I’m available to help over the phone in case u need at
My printer fuser and transfer belt did not open with error code c2152 i tried to reset the printer but not still working pls what can i do
PROBABLE CAUSES:
1. Detecting Plate not positioned properly.
Shape of the detecting plate has been modified. Install the modified Detecting Plate (p/n A02E 5033 01). Please refer to the attached procedure for
instructions on how to install the modified bracket.
Note :The following are the serial number cut-inswith themodified Detecting Plate installed:
bizhub C353 - A02E010005899 and onward
bizhub C203 - A02E012005777 and onward
bizhub C253 - A02E011005566 and onward
bizhub C353P - A02E013000060 and onward
magicolor 8650 - no cut-in available
2. Transfer Belt Retraction Sensor (PS31) mounting bracket (p/n A02E 1121 00) is fixed with a screw and it can be tilted while assembling. If the bracket is
tilted, the sensor cannot detect the Transfer Belt position properly. In order to avoid tilting the bracket, the shape of the bracket has been changed.The shape of the sensor actuator has also been changed because the actuator could touch the other parts.
PARTS
A02E 1121 00 -current Bracket
A02E 1121 11 - modified Bracket
A02E 1122 01 - current Actuator
A02E 1122 12 - modified Actuator
Notes :
a.When at the machine, please check the condition of Sensor Bracket and change the Sensor Bracket and Actuator if necessary.
b. Please refer to details in attachedBulletin Number 6252 (applies tobizhub C203/C253/C353).
3. Somepacking material was not removed froma new Transfer belt before installation. Ensure that allpacking material has been removed before the Transfer belt is installed.
4. Failure of the Transfer Belt Retraction clutch (CL7).
Check for wiring being pinched from bypass door and replace the failed parts.
PARTS
CL7 (p/n A02E M200 00)
bizhub C353 Drive Wiring/1(p/n A02E N10F 02)
bizhub C253 Drive Wiring/2 (p/n A02E N117 02)
bizhub C203 Drive Wiring/3 (p/n A02E N10Y 02)
bizhub C353P Drive Wiring/4 (p/n A02E N11A 00)
magicolor 8650 Drive Wiring/6 (p/n A02E N11C 00)
Error Code C-5102
C5102 Transport motor'sfailure to turn• The motor lock signal remains HIGH for apredetermined continuous period of timewhile the motor remains stationary
Some thing is binding the drive
