I tried hooking up the AV cables to the TV and turning the TV to channel 3 or 4, but nothing is happening.
SOURCE: "Tape Not Inserted" on Panasonic PV-DV203 palmcorder
hai, If you are service engineer you can do this problem, Please, check the cassette IN sensing Switch. The place of the Switch is right side of the mechanism, Clean S/w with IPA solution & check. It will be ok or other wise you have replace s/w or mechanism.
SOURCE: How to hook up my dvd/vhs combo to my tv with out the red,yellow and white cables
go to radio shack and get the red and white and yellow cords.
SOURCE: No sound on some channels
Check in the menu to see if the audio is on SAP. If it is change it to Stereo. Hope this helps
SOURCE: Panasonic Palmcorder PV-43 turns off with a tape inside
you definetly have a tape mech fault and this is going to have to go for repairs to panasonic.
SOURCE: no sound with ps3, connected to a 7.1 av receiver & projection tv
Hi...the HT-R800 Home Theater system has the HT-R550 receiver which could only carry Video via HDMI. you would need to connect a separate audio cale(Optical Audio Cable) to be able to get audio out of the PS3 to the receiver. Once you have hooked up an Optical Audio Cable you would need to go in the PS3 setup and putin Bitstream and Optical in the Audio Setup menu.
