20 Most Recent
Panasonic TH-42PWD6UY 42 in. HD-Ready Plasma Television Questions & Answers
Plasma TV-power light does not come on
You have burned an internal fuse on the main power board. There are 2 right next to where the main power line plugs in ( after the noise filter ). Yes, you will have to unscrew the rear plate to get to it ( about 24 screws ). You just follow where the lead goes from the plug - you will see where the fuses are - right next to where the plug mounts to the power board. To check this set your meter to ohms and check for continuity - odds are one of the two fuses is done. THIS IS A PANASONIC SPECIFIC FUSE - it cannot be replaced with one that looks like it or fits the same slot. This fuse is a time-delay slow burn fuse and replacing it with anything other than the correct type will cause more damage and possibly total the unit. The panasonic part number is K5D802BNA005 and is available from several parts retailers - just google "panasonic part K5D802BNA005" and many reputable firms will come back on the search. They cost approx. $1.95 US ( so the shipping is probably 7.00 more ) Hope this helps and be careful of the internals and static electricity from your body.
4/11/2020 2:42:57 PM •
Panasonic...
Answered
on Apr 11, 2020
My sansui plasma tv red light is always on but the tv does not show anything.What should I do?
Constant display of red indicates a panel failure. Anyway, make it sure by checking it thoroughly.
If you wish to get more details, check the site linked
below. Pull up older posts there. Check
the site with patience, as it has over 2400 posts now. All are related to electronic equipment
repair help. If you search the site in
Timeslide option, which can be selected from the drop down list at the top left
of the display window, it will be easy to locate the related post. You can also do a search by type in the
brand name to your device into its search box at the top right of display
window. Faulty screen shots to plasma displays, and reasons are described in detail by many posts. Check them. You'll get an idea about the present condition of your plasma display.http://electronicshelponline.blogspot.com/
5/2/2013 2:29:41 PM •
Panasonic...
Answered
on May 02, 2013
Troubleshooting 32 inch Philips LCD TV
Sounds like a power supply problem that typically is caused by a power surge of some sort. Check with tvrepairkit. com for their power supply kit to do the repair yourself.
2/9/2013 1:52:44 AM •
Panasonic...
Answered
on Feb 09, 2013
Viera th-p42g10a
11 blinks Fan SOS PB Board.Visit the site named 'Electro-help' for
more details. Click this link. View it in
"Timeslide" or "Flipcard" option, which can be selected
from the drop down box menu by the [Sidebar] tag, at the top left corner
of the display window. You can also
click the [Home] tab to the latest updates. It will make search easy.
There are more than 1350 posts to different brand TVs now. Pull up older posts
there.
11/28/2012 7:43:11 AM •
Panasonic...
Answered
on Nov 28, 2012
I have a panasonic plasma th46pz80u. Last week
On Panasonic 32LX TVs this is a known fault, repairable by a firmware upgrade. John Lewis in the UK sent out an engineer under their free 5 yr TV guarantee and completed the firmware upgrade for me. The only other store to compare with them for price and service is Richer Sounds but I believe you now have to buy the warranty for 10% of the purchase price. This problem will persist unless the upgrade is completed. For those of you in the UK, I would insist the seller repairs the problem under the Sale of Goods and Services Act as the TV is not fit for purpose without the upgrade.
8/2/2011 3:46:55 AM •
Panasonic...
Answered
on Aug 02, 2011
My 32" plasma TV (ikon)
My 32" IKON Plasma TV not getting on. when press power button on remote LED on TV getting bling only
Kindly Help
Abdul Rasheed
6/2/2011 3:19:07 PM •
Panasonic...
Answered
on Jun 02, 2011
The Panasonic plasma model I
The problem is most likely a bad SC board, if you can find the board online it will probably run you between $250 - $300 for the part. A repair facility will charge you between $400 - $500 total to fix the unit if that is all that is wrong with it.
5/4/2011 4:21:42 PM •
Panasonic...
Answered
on May 04, 2011
LG 32" Plasma TV power-on problem
Your power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
hope this helps...
7/2/2010 2:30:30 PM •
Panasonic...
Answered
on Jul 02, 2010
Akai LCT 2662 will not turn on
I'm surprise to see the repair shop telling you there nothing they can do.
The power supply can be fix if you take the time to troubleshoot it. However this is not a DIY project.
The failure is in the capacitors that are bulging out of the top or bottom. Quite visibly defective.
4- 3300uf @35V
8- 2200uf @25V
7- 1000uf @10V
1- 1000uf @6.3V
3- 100uf @25V
1/22/2010 1:25:50 AM •
Panasonic...
Answered
on Jan 22, 2010
