SOURCE: samsung washing machine
http://www.repairclinic.com/SmartSearch/smartsearch.aspx?SearchText=%60Awashingmachine
Go here for a new filter. If the link does not work, go to the repairclinic website first.
SOURCE: repair of samsung (karisma ) washing machine
Water draining is indicative that the drain valve is left open allowing water to escape even during regular/wash cycle and not only on drain/wash cycle completion. this could be brought about by:
1. laundry material, debris, safety pin, clips or some other foreign material has lodged itself prohibiting the drain valve in closing properly; or
2. the mechanism (solenoid) closing the valve is jammed in the open position.
Corrective measure calls for inspection and possibly cleaning or solenoid/control mechanism repair or replacement. Often these can be found at the bottom or near bottom of the machine below the tub.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
SOURCE: filter needs cleaning as water does not empty
I was unable to locate your filter in your machine but if it would help after you clean the filter you could install an inline filter between the valve and the hose. This is an RV filter it just screws on like the hose.
http://www.flowpur.com/html/rv_filters.html
The FP12GKE shows just how easy it is. Any RV filter will work.
Testimonial: "Many thanks "
SOURCE: Problem: water supply to washing
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
SOURCE: Samsung washing machines water drains continously
The drain hose is too low, you need to lift the height of the drain hose as it is siphoning and won't be able to fill to the required level.
