20 Most Recent Samsung WA5451ANW 4.7 cu. ft. Top-Load Washer Questions & Answers
2answers
I get an error code PE on Samsung washer WA5451washer
PE error code is a pressure sensor code, and more than likely the sensor will need to be replaced. Try unplugging the unit for about 5 minutes and see if it will clear it out. If not, will need to replace pressure switch and hose (switch looks like a little UFO under the console, pretty easy job.
10/9/2022 1:27:02 PM • Samsung... • Answered on Oct 09, 2022
2answers
How to reset samsung washing machine
http://www.samsung.com/us/support/owners/product/WA5451ANW/XAA
3/23/2019 11:15:08 AM • Samsung... • Answered on Mar 23, 2019
3answers
How to calibrate samsung top load washing machine
there should be another 7 letters/numbers after wa14 maybe the full model number is on the back or in a manual
1/10/2019 10:26:19 AM • Samsung... • Answered on Jan 10, 2019
Rinse and spin cycle keeps repeating at 11 minute time to 17 minute time and won't stop
Sounds like your washer does not empty enough water for the spinning to stop. Have you check that the filter(s) are not clogged?
8/30/2017 8:35:50 PM • Samsung... • Answered on Aug 30, 2017
Samsung WA5451ANW top will not open. Code
Have you tried to tilt the washer? When I tilted my washer 15 - 30 degrees and then I could open the lid. My problem was that I had a clogged filter I have not seen before.
8/30/2017 8:32:14 PM • Samsung... • Answered on Aug 30, 2017
My Samsung Model#WA5451ANW/XAA washer keeps repeating the rinse and spin cycle over and over and my clothes are still wet because spin cycle is not spinning clothes fast enough.
From the information you have supplied, I suspect that the machine is not draining the water away, 1] Check that the drain pump is working (it would be easier to hear it running, before the machine starts the spin cycle, or if your machine has a "drain down" feature) 2] If the pump is running, stop the machine and unplug it from the mains power. Remove the machine drain tube from the point where it is plumbed into the household waste pipe, and lay it down into a bucket, or large pan and allow the water to drain down [ you should expect to get up to 2 gallons (10 Litres) of water from the machine] Allow the water to drain down completely by holding the drain hose as low as possible into the bucket. 3] once the water has drained completely, remove the drain hose from the pump and check that the drain hose is not blocked. 4] If the hose was clear, and the pump was running (in tests [1] & [2] ), it will be necessary to check that the drain pump, and the main hose from the tub to the pump are clear of obstructions. Remove any foreign objects, and re-assemble the hoses to the pump to the machine, and the drain hose to the domestic plumbing. Plug the machine into the mains power, and and set the machine to run on the "last rinse" and "spin" cycles and test to see if the problem has been rectified. I hope this helps cure your problem.
10/14/2016 7:36:18 PM • Samsung... • Answered on Oct 14, 2016
How do I correct a "dc" error?
google the brand , model , and error code to find out
7/29/2015 2:22:33 PM • Samsung... • Answered on Jul 29, 2015
0answers
8E error code
Be the first to answer 4/30/2015 4:27:55 AM • Samsung... • Posted on Apr 30, 2015Be the first to answer
8E error code on samsung top load direct drive washer
Samsung has us replace Mems sensor, main harness and user interface board. They do not have away to test the mems sensor in the field.
12/30/2014 6:45:33 PM • Samsung... • Answered on Dec 30, 2014
0answers
Clean samsung
Be the first to answer 8/1/2014 3:03:07 AM • Samsung... • Posted on Aug 01, 2014Be the first to answer
Samsung washer had ND code, checked for clogs, could not find a filter on my machine, drain pump is in back inside panel, I removed hoses and found nothing, now machine will not start a cycle or drain
to start with for your first problem "NF"if u Insert the drain hose too far into the drain it may cause a syphon effect stopping any water from draining out of the washing machine. and that will cause an "Nd" error.and 6e9df0b6-14e5-4444-9dca-eea3526ce7ee.jpgmake sureto the make sure there is power to the washer and if there isn't there is a good possibility it is the
Bearing Seal and Bearings:
5/29/2014 10:56:48 PM • Samsung... • Answered on May 29, 2014
0answers
How to reset
Be the first to answer 4/15/2014 4:13:53 AM • Samsung... • Posted on Apr 15, 2014Be the first to answer
0answers
Model WA422PRHDWR
Be the first to answer 3/22/2014 3:43:06 AM • Samsung... • Posted on Mar 22, 2014Be the first to answer
Samsung WA5451ANW 4.7 cu. ft. Top-Load Washer Logo
49 questions posted
Top Samsung Washing Machines Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Washing Machines
Most Popular Question
fault error code 8e
  • Washing Machines
