We have a GE washer model GTAN5250DOWN. We purchased it in 2012. There is a PreciseFill feature to set automatically the water level in the washer. Since a year or two, this feature doesn't seem to work and the water level is always at the maximum. There is no overflow and everything works perfectly but the PreciseFill feature. This was working fine at least for the first 5 years of usage.
SOURCE: ge gsl25jfrfbs water disoenser not working
Solenoid or the dispenser switch.
The water supply line connects to a water valve on the Ref. this water valve has two solenoids, one for the ice maker and one for the water in the door. Check this solenoid with an OHM meter.
The dispenser switch should send 110 volts to the solenoid. Check at the solenoid while pushing the water switch in the door.
SOURCE: I have a GE Profile,model PFS22SISBSS,3 years
Possible main pcb failure failure which would cause everything to cut out and restart . Is the compressor or back of the appliance hot ?? Do all the control lights go out when the compressor cuts out ??
SOURCE: Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
SOURCE: ge profile washer WPSR3100W1WW won't agitate
I see this pretty regular. You have a bad transmission. This is very common with the older GE's. To replace the transmission will run around $340 / $400. Not sure about your area. Just be glad you got this much use out of it, you are one of the very few that have. From 1998 till 2007 I owned my on repair company where I did GE's warranty work in my area for them. During that time period. When I found a GE washer under warranty doing what you are describing. GE would warranty the whole machine. They would have me destroy the machine after I would deliver the customer a band new one. GE knows they had a bad transmission and it cost them a lot of money. It was cheaper for them to replace the washer than have me repair it. The transmission list price was $298.00 back then. A word of advice, when you replace it. Buy a Whirlpool, Kenmore, Maytag. These brands hold up the best. I have the least service calls for Whirlpool and Kenmore. Both are made by the same people. Kenmore is made for Sears. Good Luck.
Please rate this solution if helpful. Thanks
SOURCE: washer is won't spin
Hi just read your posting.Now from the information in your posting the machine is not draining.Is this correct?Now what I need you to do is to 1st remove all the clothes from the machine and bail out the water by hand with a small pot or bucket.Only bail enough water so it does not leak out when you lean it back against the wall.Now I need you to look under the machine ,Hence the reason for bailing some of the water out, and tell if your pump is the type with a red or black fan attached to it.The pump is located under the machine to the front right.If you have this type of pump turn the fan with your hand clockwise a few times then anticlockwise a few times.This is to loosen it up if the pump is blocked.If the pump frees up and you can turn the fan easily then put the machine back upright and select a spin cycle and push the start button.Please reply and and tell me how you got on or if your pump is the one without the fan,also reply back if it does not drain and you require more help.
