20 Most Recent GE Profile WPRE6100G Top Load Washer Questions & Answers
5answers
WH45X10060 - is this a joke?
do you need just the hub or do you also need the basket...I can sell you a hub.. let me know
6/27/2023 8:16:19 PM • GE Profile... • Answered on Jun 27, 2023
2answers
GE WASHER LIGHTS FLASHING BUT NOT WORKING
It won't change because the cycle was incomplete and the safety control is preventing a restart. Until you get professional onsite service; unplug the washer; make certain all of the water is drained out, and disconnect the hoses. Have someone help you tilt the washer forward and lay on the front side. Pick it up again and reach into the tub area and spin the tube around, and kind-of move it side to side. Hook it back up, plug it into the power supply and reset the timer to start a short wash. Try to start and see if you get any action. If after all of that; nothing changed, the timer on the circuit board is stuck where you left off when the unbalanced load shut it down.
10/27/2021 4:01:27 AM • GE Profile... • Answered on Oct 27, 2021
Washer drains but sometimes doesn't always spin.
Depending what unit u have most don't have belts now days the have direct drive couplers or single unit motors which act as motor and transmission all in one but more to ur point sounds like ur motor is getting week and needs replaced
12/20/2019 6:07:42 PM • GE Profile... • Answered on Dec 20, 2019
2answers
What should l check to see why my washer won't drain
If spins, pump problem. If no spin thats problem. Motor reversing switch bad, possibly bad v belt on the bottom.
11/20/2019 5:55:38 AM • GE Profile... • Answered on Nov 20, 2019
2answers
Washer won't agitate or spin
Hello there and welcome to fixyathere are several things that you will need to check first ok please verrify the followingIt doesn't pump or spinIf it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.It pumps, but doesn't spinIf your washer pumps out the water but doesn't spin, check these:The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
12/30/2018 2:05:53 AM • GE Profile... • Answered on Dec 30, 2018
0answers
GE Top Load Washer Loud Squealing Noise
Would check belt for tightness and it is also possible you have a dry bearing in pulley, motor etc.
1/16/2018 3:09:28 PM • GE Profile... • Answered on Jan 16, 2018
If I run a load with the water at the "Large" or
check water solenoid or leakage from hoses or water level swith
12/18/2017 6:58:48 AM • GE Profile... • Answered on Dec 18, 2017
0answers
Ge load size selector broken
You can buy this part, suggest you go online and purchase it. Contact this website: Appliance Parts Accessories Repair Help
5/19/2017 11:29:22 PM • GE Profile... • Answered on May 19, 2017
New water pump isn't working. There were 3 wires
lucky that the machine is plastic or you would be getting a shock red wire is active , black wire is neutral and the green with yellow is ground all of the wires have a color code for a purpose and must all be connected correctly connect the pump correctly and the fault will dissapear
5/12/2017 11:54:41 PM • GE Profile... • Answered on May 12, 2017
Load size dial won't set anymore, just spins freely
Most likely the knob is defective, order a new one.
4/25/2017 11:27:23 PM • GE Profile... • Answered on Apr 25, 2017
GE Profile WPRE6100G Top Load Washer Logo
579 questions posted
Top GE Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Virgil Watts
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
GE Washing Machines
  • GE Washing Machines
Most Popular Question
machine works but will not light up
  • Washing Machines
