20 Most Recent GE Spacemaker Washer and Dryer Electric Laundry Center Questions & Answers
What does a blinking green light on a GE stackable washer/dryer mean
Can you provide more information on the year of your stackables and if you have the exact model or serial number, that would be helpful. Thanks.
3/25/2018 7:23:06 AM • GE Spacemaker... • Answered on Mar 25, 2018
Agitator wont agitate. The driving
Washer drive hub P#WH40X10001
7/10/2017 1:54:02 PM • GE Spacemaker... • Answered on Jul 10, 2017
My GE spacemaker washer is blinking and will not work
I have a he gtup270emww washer used very little. The washer was overloaded and quit working full of heavy wet clothes and water. The washer agitator does not operate. The water does not drain.
The light blinks. I have un plugged the washer to reset the motor and lifted and closed the lid 7 times. I drained the water by hand.
When I try to operate the washer, it adds water for 30 seconds, the water shots off and the green light blinks.
What is the fix?
6/29/2017 7:24:24 PM • GE Spacemaker... • Answered on Jun 29, 2017
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
1/10/2016 9:31:09 PM • GE Spacemaker... • Answered on Jan 10, 2016
0answers
2answers
Washer does not "click" to drain and spin cycle
Hi, Check the lid switch. Most models will not drain or spin when the lid switch is bad.
If I can get the model#, I wil try and asist you further.
Vic
3/19/2015 4:25:16 PM • GE Spacemaker... • Answered on Mar 19, 2015
My washer is leaking and won't agitate properly.
I had a similar problem with my GE Washer that leaked, and still won't spin. I fixed the leak though. It was from the pump, which is in the bottom front, and somewhat easy to get to. I just removed the front cover, and the pump is on the right side. The pump itself was not broken but one of the screws was corroded with rust, so water leaked from that area. I just had to take it apart, put in a new screw to get a tight seal, and no more leak.
3/17/2015 1:47:05 AM • GE Spacemaker... • Answered on Mar 17, 2015
LIGHTS ON BUT WASHER WON'T START
Try fuse box turn off & turn on , May you have only 110 volt need 240 v
1/29/2015 2:58:07 AM • GE Spacemaker... • Answered on Jan 29, 2015
3answers
Need to find a replacement
I found it on amazon. Take a look here: Amazon com ge spacemaker dryer knob. I hope I have helped. Cheers
12/1/2014 11:43:50 PM • GE Spacemaker... • Answered on Dec 01, 2014
Model wwp1180g
Look at it carefully to see whats in the way of the belt removal. If its still on the unit best to take some pics of it so you have a reference to make sure everything goes back where it should.
8/20/2014 1:37:22 AM • GE Spacemaker... • Answered on Aug 20, 2014
My machine fills and spins wont wash or rinse
The coupler that connects the motor to the transmission is broken. Replace the coupler.
8/11/2014 4:33:33 AM • GE Spacemaker... • Answered on Aug 11, 2014
Fills with water but wont wash
When in the wash cycle do you hear the motor running? If yes the motor to transmission shaft coupling is broken. Replace it.
8/11/2014 3:42:05 AM • GE Spacemaker... • Answered on Aug 11, 2014
GE Spacemaker Washer and Dryer Electric Laundry Center Logo
415 questions posted
Top GE Washing Machines Experts
Virgil Watts
Steve Sweetleaf
Steve Sweetleaf
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
GE Washing Machines
  • GE Washing Machines
Most Popular Question
need find replacement
  • Washing Machines
