20 Most Recent GE WSXH208A Front Load Washer Questions & Answers
CONTROL LOCK and Can't start the GE front load washer - WSSH300GWW
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
5/29/2022 1:11:19 AM • GE WSXH208A... • Answered on May 29, 2022
2answers
I can't wash immediately because the "wait 8 hrs" button won't turn off
7/23/2019 10:03:54 PM • GE WSXH208A... • Answered on Jul 23, 2019
The old door latch switch for the washer part # is 131269400 and the replacement part is # 131763202. There are 2 additional prongs in a bank of 4, and the old part only had 2 wires. Which 2 are to
It is a circuit so test the connections on the washer side.... insert a lead into one and a lead into the other... repeat until you get the correct two... right 2 will give you a reading the wrong ones nothing
4/11/2018 6:22:29 PM • GE WSXH208A... • Answered on Apr 11, 2018
I have a GE stackable combo washer and dryer MODLE
please go to the website and download the user guide to give you an idea whats going wrong eric
12/27/2017 12:14:59 AM • GE WSXH208A... • Answered on Dec 27, 2017
2answers
Feather pillow exploded and now door is locked. what next?
We need the exact model number,
10/19/2017 1:55:51 PM • GE WSXH208A... • Answered on Oct 19, 2017
2answers
GE Front Loading Washing Machine seems to be holding water....
The high speed spin of a front load washer should normally do a good job of getting squeezing out the water but if there is an oversudsing condition that makes it hard for the drain pump to operate then the suds and water will just stay there. First make sure there is no actual clog in the drain line then run a load with no soap or detergent and see what happens. It's always better to use a low suds detergent with this type of machine
10/12/2017 12:17:47 PM • GE WSXH208A... • Answered on Oct 12, 2017
My GE Washer continues to keep pausing during the wash cycle. After we push the button to restart it pauses again after 5 to 6 minutes and continues this throught out the entire wash cycle. We also we
Please, check to insure that your washer is properly grounded. If you do not know what that means, call an electrician. Modern wash machines are controlled by circuit boards that operate on low voltage and are vulnerable to static electricity. Spikes or gaps in the electrical service from your power company could also be the problem. Your electrician should be able to help you with that as well.
10/5/2017 7:47:11 PM • GE WSXH208A... • Answered on Oct 05, 2017
0answers
Wsxh208a1ww
Be the first to answer 9/19/2017 12:36:03 AM • GE WSXH208A... • Posted on Sep 19, 2017Be the first to answer
2answers
Water leaks out front center of door during the
Check the door gasket for any damage. A rip or a tear could be the cause of the leak.
6/8/2016 5:06:41 PM • GE WSXH208A... • Answered on Jun 08, 2016
GE front load washer will not complete the rinse & spin cycle
1) 1st check the filter under the machine (it unscrews behind the access panel 2) open front door and pull back the rubber membrane to see metal and clean out the debris blocking drain holes 3) remove the drain hose from the machine (spring clip) and try and run water thru it and keep blowing out the junk and re-attach 4) run the machine thru 2 cleaning cycles w/bleach and without bleach 5) start using less detergent
2/21/2016 6:05:56 PM • GE WSXH208A... • Answered on Feb 21, 2016
GE WSXH208A Front Load Washer Logo
1,215 questions posted
Top GE Washing Machines Experts
Virgil Watts
Steve Sweetleaf
Steve Sweetleaf
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
GE Washing Machines
  • GE Washing Machines
Most Popular Question
ge front load washer wont start model
  • Washing Machines
