I have replaced defrost heater and defrost sensor in fridge but top still not cold and icing up at evaporator samsung srs584dp
It sound like your system is low on refrigerant. After you make sure the condenser is clean, and if you have a fan on the condensor that is is operating, check the temperature of the smallest refrigerant line coming out of the compressor about 5 or more inches from the compressor. This is the high pressure line and during normal operation should be around 140 degrees when fully charged. It is my experience about 5 percent of the mass produced refrigerators coming into this country is not charged properly and can cause the symptoms you describe. About 1 percent develop leaks and lose refrigerant. If your line is warm to the touch or barely warm to the touch, you will need to have your system leak checked and recharged by a competent refrigeration tech.
Hope this helps.
