20 Most Recent U-Line CO2075F-B Echelon Refrigerator Ice Maker Combination Questions & Answers
4answers
Ice maker freezes up
Icemaker Fill Tube Freezing Make sure the water supply is greater than 20 psi. If too low, the water valve won't seat properly and it'll "weep." Common causes of low pressure are gunked-up saddle tap valves, kinked water supply line, and using a reverse osmosis filter to supply water to the icemaker. Check to see if the black, flexible portion of the fill tube is wrinkled, twisted, or kinked which can cause ice dams that block the fill tube. It turns out that the manufacturer's have been scratching their heads about this, too, and have concluded that the new fill tube air slit design helps prevent this problem.
10/2/2014 7:24:18 PM • U-Line CO2075F-B... • Answered on Oct 02, 2014
0answers
GE side by side refrigerator freezer
some times if the water inlet valve has a small drip it will leak into the flume and freeze up and stop all water from entering
11/22/2013 11:42:10 PM • U-Line CO2075F-B... • Answered on Nov 22, 2013
The bucket that holds the ice is freezing all the ice together and then it will not come out of the dispenser
You have a bad water valve, this causes water not to stop entering the unit and causes one big cube. You didn't mention any ice or frost behind the ice bin so I will assume you have none. the water valve should correct this issue.Good Luck I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
11/17/2013 4:26:00 PM • U-Line CO2075F-B... • Answered on Nov 17, 2013
Water supply to the ice
Hi
Over time the inlet valve becomes partially plugged, reducing the outlet pressure and reducing the water flow rate into the icemaker. If the flow rate is too low then the water will gradually freeze in the tube until it becomes blocked entirely. Many times low water pressure will cause this. You can perform a taste. Get a piece of tubing and attach it to the inlet valve. Run this piece to a container and see if you get any water while the power is off to the valve. You might have a valve that is not shutting completely off. Hard water might cause this. Killing the power to the valve will make the valve inoperable. Actually the purpose of killing the power is to see if the valve is allowing water to bypass even when there is no signal from the switch to do so.Bad inlet valve could be the possibility. So it needs to be ordered and replaced because the valve isn't sealing off properly and it's causing the water to trickle through or drip through the fill tube sometimes, then it freezes before it reaches the icemaker and over time it will clog up the fill tube completely. Please get back to us if you have further query else please accept the suggestion. Thank you for contacting fixya.com
8/4/2011 11:50:41 PM • U-Line CO2075F-B... • Answered on Aug 04, 2011
After having the ice maker
Sorry to hear about your problem. Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues, this does sound funny, but this is why your refrigerator side is warm, or not cooling.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
12/29/2010 5:43:28 PM • U-Line CO2075F-B... • Answered on Dec 29, 2010
Why does my U-line refrigerator keep frosting
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
9/11/2010 9:51:11 PM • U-Line CO2075F-B... • Answered on Sep 11, 2010
Ice maker will not push
Hi
Please check the bellow link regarding your query…
http://applianceandair.com/Icemaker/icemaker.html#norelease
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
9/1/2010 2:34:08 PM • U-Line CO2075F-B... • Answered on Sep 01, 2010
GE Monogram -- Ice freezes IN THE CHUTE and blocks the chute
My ice cube chute kept freezing, and I realized the Access Door was stuck open. I was able to replace it without taking the door apart.
6/6/2010 12:31:57 AM • U-Line CO2075F-B... • Answered on Jun 06, 2010
U-line UC02175 water inside pooling under veg
Well sounds like your ice maker evaporator drain hole is frozen, every time the unit goes into defrost cycle, water backs up and leaks down to the drawer. You can try turn off the refer for 48hrs with the doors open, most case it will reset by it self. If it is happening again in few weeks, then you evaporator drain pan heater is not working. Also make sure the doors are shut all the time.
3/2/2010 6:23:20 AM • U-Line CO2075F-B... • Answered on Mar 02, 2010
Blinking light on 2075DWRRB
Thermistors are calibrated together with the board. When you order a board thermistors will come with them. When you get the board (display) a thermistor will be with it. You will have to pull unit out. remove the back panel and you will see the wires for the thermistor on your left and it plugs into the right side. That should help you. just remove permagum and pull the thermistor out. It just site in a tube.Part number for that model is 68005
10/13/2009 4:53:06 AM • U-Line CO2075F-B... • Answered on Oct 13, 2009
My icemaker will run water
I did not ever speak with a person. Got disconnected.
9/15/2009 10:32:05 AM • U-Line CO2075F-B... • Answered on Sep 15, 2009
U-line CO 2075 refrigerator stopped working, only
OK I'm guessing you have a clear icemaker. Not a co2075. When you replace the board you MUST replace the thermistors that come with the board. The board and thermistors are calibrated together. What is your model number? A clear ice maker has thermistors inside tubes. Except for the one on your filter dryer. Lets start with the correct model.
8/26/2009 11:15:40 PM • U-Line CO2075F-B... • Answered on Aug 26, 2009
Ice Maker frost and freeze where ice drops into refrigerator door
You need a service guy to look at it. It could be water leaking or a simple case that the flap isnt sealing and the ice melts and then freezes the flap open
8/23/2009 5:23:04 AM • U-Line CO2075F-B... • Answered on Aug 23, 2009
Leak out of the from of the ice machine - flashing p1
P1 means a problem with your drain. Most of the time its a kink in the line. Double check your drain line or it could even be a bad drain pump.
8/23/2009 5:20:22 AM • U-Line CO2075F-B... • Answered on Aug 23, 2009
Open Thermistor on U-Line
It might be a bad thermistor. I would need the exact model number. It could be a open harness as well.
8/23/2009 5:18:50 AM • U-Line CO2075F-B... • Answered on Aug 23, 2009
Ice cubes freeze together and won't come out chute
too much water going into it. Decrease the water remove the cover and you will see a screw with a spring around it. Turn it clockwise to decrease the water.
8/23/2009 5:17:35 AM • U-Line CO2075F-B... • Answered on Aug 23, 2009
Refrigerators Logo
34 questions posted
Top U-Line Refrigerators Experts
Kardoc
Jorgie  the...
Jorgie the...
ADMIN Andrew
ADMIN Andrew
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • U-Line Refrigerators
Most Popular Question
after having ice maker
  • Refrigerators
