20 Most Recent
U-Line 2115R Echelon Series 15" Refrigerator, Auto Defrost Questions & Answers
Power went out; now U-Line has no power. Circuit
1st make sure you dont have 2 dashes in the display. If you do then the board will have to be programmed. If its blank or 0 then unplug the unit for a min. then plug it back in. It should work.
The alert notification is from a u-line refrigerator and beeps even when door fully closed
Since you did not mention what make it is .
Its usually dirt in your door seal causing your refridgirator to understand its not closed since its not sealing properly . clean the door seals and try .
Or there is a technical glitch in electrical system and you need a repairman .
Also there is usually a way to disable the alarm and you need to check your user manual for that to disable it ill its fixed
6/1/2018 4:50:59 AM •
U-Line...
Answered
on Jun 01, 2018
