Samsung DVD-VR375 DVD Recorder/VCR Logo
Posted on Jul 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Plays vhs tape in only black and white (no color).
When i play a vhs tape in the samsung dvd vr375 recorder it displays on the tv in black and white (not color), when I play a dvd it displays on the tv in color (good). how do i connect it up to make vhs tapes play in color? i had it connected to AV2 then changed the connection to HDMI and both methods still only played vhs tapes in black and white.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 19, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4063
Points
My old series of ROOTS is playing in black and white and says on cover that they are in color
Vinho Xie
Level 3:
Genius:
  • Samsung Master 1,419 Answers
  • Posted on Jan 04, 2022
Vinho Xie
Samsung Master
Level 3:
Genius:
Answers
1419
Questions
0
Helped
414119
Points
4431
Recently, some users frequently reflect that their DVD players could only present the pictures in black and white. This is quite annoyed by most people, which may directly prevent them from enjoying a wonderful movie or a video. Why is my DVD playing in black and white? This is the main topic to be discussed in this article.
Source: Why is My DVD Playing in Black and White
Yandel Vargas
Level 1:
  • Posted on Jul 25, 2020
Yandel Vargas
Contributor
Level 1:
Answers
Questions
0
Helped
4063
Points
1helpful
Cannot play a VHS tape. Push in and pops out.
The belt on the loader motor is slipping. This causes the tape to not completely position itself to allow the tape to load around the drum. The machine senses this and ejects the tape.
2answers
How to record a vhs tape to dvd on a samsung 1080
Hello
1.The VHS/DVD player must have recording capabilities.
2 Connect both players to a television so that you can make sure you are recording the appropriate content. You can also monitor the speed at which the VHS is copying to DVD.
3. Place the VHS in the VHS player and the blank DVD in the DVD recorder. You will need to use your remote and go through the menu options to choose the correct format for recording. The formats should be clearly labeled and outlined in your instruction manual. Choose the option that will read something like "VHS to DVD." You may also have to choose recording speed, which varies per blank DVD that you purchase. Every player is different, and every menu will vary slightly. If you have questions, refer to you individual manual.
4. Select the option that works best for you and hit "Play" on the VHS player and "Record" on the DVD recorder. To play the finished DVD, you will select the playback option.
THANK YOU
2helpful
VHS to DVD: audio and visual dont match on playback
Hi, this is a problem with cramming too much info onto dvd.
For a good quality dvd, it needs to have about 1.5 to 2 hours of video on it. The more you put it the lower the quality it becomes. Don't forget though , it will never be better than the original.unless you have some specialist software to tidy up sound and flickers in the video.
So I would stick with one tape to one dvd if you want to keep the quality.
DVD's are cheap anyway, you can buy a spindle of 50 Verbatims for £10.
I hope this has helped you understand a little better, but if you need more assistance, then please ask.
Regards - Anthony
2answers
Tried dubbing VHS to DVDs, worked okay. But I cannot get the DVDs to play on my laptop. I used DVD-RWs. What kind of DVD do I have to use?
It depends on the specifications of the DVD drive in the laptop. Go to the website for you laptop manufacturer and look up the specifications. You also have to have DVD playing software. It is was not always included with the Windows operating system, although some kind of player may have been packaged with your computer when sold. DVD-RWs are recorded at slower speeds, which makes bigger dots and make not work with all DVD playback drives.
2helpful
2answers
VHS plays in colour and DVD plays in black and white.
there is a circuit in the color section to put the tv to black and white if the color subcarrier is missing from the broadcast signal.
it is called a color killer and needs to be adjusted.
it is for a technician to do.
it operates off the 3.58mhz color subcarrier.
I have a Samsung DVD-VR357. I get no color on vhs tapes. I only get black and white.Picture is good. DVD color is ok. When I copy VHS to DVD, the DVD copy is in black and white also. DVD copies from...
Are you trying to copy a comercial VHS tape to DVD?
If you are then macrovision copy protection system on either the tape or in the machine is the reason for the loss of colour.
There's not a lot you can do about it. If you want to copy commercial material you will need to transfer it to a computer and get a program to do it. But unless it's unavailable it is cheaper to buy the DVD version I have found and you will get better picture and sound too!
If it does it with a none comercial tape (ie something recorded of the TV). Then it could be a head fault or something else. In which case try cleaning all the heads guides etc first.
2answers
How to record a VHS tape to a DVD disc
Read your manual first to make sure the unit will do this.If it does chances are it won't record unless it has a decoder built in.Most VHS tapes have macrovision protection that prevents you from copying them.It will however,record homemade VHS tapes.There are decoders out there you can buy to enable you to copy VHS tapes.
Pal to NTSC
Hi, Based on your post/description, you need to get a multi-system TV to go with your multi system VCR if you are going to playback VHS tapes from different regions. You are quite correct "Plays NTSC tapes to NTSC, Will not Play Pal to NTSC" to play PAL (even Secam) you would need a PAL/Secam TV. They have a different system for color and audio. In some cases, you can still play PAL but you get it in black & white and picture squeezed from top & bottom. Hope this be of some help to you. Good luck and kind regards.
2answers
VHS tapes are black and white
The tapes are B/W or one of the playback video heads is not making contact with the tape. The video head may need to be adjusted. You can take it in to get it fixed or buy a new one. The unit today is worth around $25-$30.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
