20 Most Recent
Samsung DVD-VR375 DVD Recorder/VCR Questions & Answers
Want to unlock region codes on my Samsung vcr/dvd
Do the following step to make your DVD player region free..
1.Turn machine on without disc inside
2.Press menu button
3.Enter region code (See below for list)
4.A highlighted 'region area number' will appear in the upper left corner (some players)
5.Press 9 to change the region number to multi-regional
6.Turn DVD off
(remove power from mains)
next time when u power on the DVD ,it will be region free.
region 1 - 29334
2 - 38767 or, 5 7 5 3 8
3 - 56732
4 - 76884
5 - 53814
6 - 24462
ok
4/7/2020 6:55:23 AM •
Samsung...
Answered
on Apr 07, 2020
Samsung DVD-VR375 - can't chage from region 1 to region free
I used this and it worked for me!:
1/Turn machine on without disc inside
2/Press menu button
3/Enter region code (See below for list)
4/A highlighted 'region area number' will appear in the upper left corner (some players)
5/Press 9 to change the region number to multi-regional
6/Turn machine off
R1 - 29334
R2 - 38767 or, 5 7 5 3 8
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
3/31/2020 7:04:10 AM •
Samsung...
Answered
on Mar 31, 2020
Can't dub from Samsung VR8606 to another device
If you have a scart socket on the back of the vcr poss marked av1.Connect a scart lead to this and if the dvd recorder has scart sockets connect to the one marked av2.Then put the vcr on play and the dvd on av2 and you should be able to record,hope this works.Jamie
12/2/2019 2:52:03 AM •
Samsung...
Answered
on Dec 02, 2019
Lost users manual for sumsung
Please click on the link below to be able to access the manual of your samsung dvd-vr375 recorder/vcr combot thi
The exact manual for Samsung DVD-VR375 DVD Recorder / VCR Combo is not available but this is the best manual that fits in for your Samsung DVD-VR375 DVD Recorder / VCR Combo
http://www.samsung.com/africa_en/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=501&prd_mdl_cd=DVD-VR355%2FXFA&prd_mdl_name=DVD-VR355&srchword=DVD-VR355
paste the link in the url position and download the manual.
Hope this helped.
11/25/2019 1:09:55 AM •
Samsung...
Answered
on Nov 25, 2019
Problems changing region code on Samsung DVD player VR 375
HELLO!
Give these a try!
Power ON
Press MENU
Enter code 57538
The current region code appears
For codefree/multi-region press 9
Press Open DVD door button
Power OFF and power ON
You could also try this!
Turn player on without disc inside
Press MENU button
Enter your region code (See list below)
Highlighted 'region area number' will appear in the upper-left corner (on some players)
Press 9 to multi-region the machine
Turn machine off
Region 1 - 29334
Region 2 - 38767 (or 5 7 5 3 8)
Region 3 - 56732
Region 4 - 76884
Region 5 - 53814
Region 6 - 24462
Have a go and good luck! (:-)
11/7/2019 2:23:30 AM •
Samsung...
Answered
on Nov 07, 2019
Unlocking region code on DVD Samsung VR 375 player
Though can try this:
1. Power ON
2. Press MENU
3. Enter code 57538
4. The current region code
5. For codefree press 9
6. Click on the Open DVD door button
7. Power OFF and power ON
8. Enjoy!
10/31/2019 8:17:42 AM •
Samsung...
Answered
on Oct 31, 2019
I need philips universal 4 digit remote codes
Not sure I can help. You might do well to call Samsung 800-SAMSUNG. But I have the codes that should work if you were hooking the Samsung to a Philips set top box or cable box. Perhaps they are the same? (And how lucky are you that you landed this jewel! I love this unit!
9/25/2019 12:59:48 AM •
Samsung...
Answered
on Sep 25, 2019
How to record a vhs tape to dvd on a samsung 1080
Hello
1.The VHS/DVD player must have recording capabilities.
2 Connect both players to a television so that you can make sure you are recording the appropriate content. You can also monitor the speed at which the VHS is copying to DVD.
3. Place the VHS in the VHS player and the blank DVD in the DVD recorder. You will need to use your remote and go through the menu options to choose the correct format for recording. The formats should be clearly labeled and outlined in your instruction manual. Choose the option that will read something like "VHS to DVD." You may also have to choose recording speed, which varies per blank DVD that you purchase. Every player is different, and every menu will vary slightly. If you have questions, refer to you individual manual.
4. Select the option that works best for you and hit "Play" on the VHS player and "Record" on the DVD recorder. To play the finished DVD, you will select the playback option.
THANK YOU
3/29/2019 8:37:28 AM •
Samsung...
Answered
on Mar 29, 2019
Need to attach dvd/vcr player
DVD/VCR will take inputs of either component BGR RW or composite YWR and will provide either composite or HDMI output. My suggestion is to take the "best output" from the cable box you can and use the HDMI output to your HDTV. This will take the best your cable will offer and give your TV the best signal to use.Cable box ------ to DVD/VCR ------ to HDTV.
8/13/2015 7:40:10 PM •
Samsung...
Answered
on Aug 13, 2015
