Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key. (Sub power must be "on" located on side of the control panel)
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
change Fuse. : fuse is on the front left side, change for 63mA and it will reset. Is for Konica Minolta Bizhub Fuser and Transfer belt reset fuse's for C200 C203 C253 C353 C250 C252 C300 C352 C350 C351 C450 C451 C550 C650 C452 C552 C652 will save $ 250,=https://www.amazon.co.uk/Konica-Minolta-...
SOURCE: request
if fusing unit life is over you must change it. other spearparts you can order from konicaminolta service.
SOURCE: Can i reset my Konica Minolta C250 transfer unit
On your transfer unit there is a .80 amp fuse you can replace. this will reset your belt. make sure you use .80 amp or it will not work. on your fuser there is an inline 1/16 amp fuse next to the plug you can replace for that.
SOURCE: I have a konica Minolta bizhub C250 and the screen
I can only tell you they are definately resettable as I do it all the time.
The fuser "fuse" is located in the connector wiring. Once you get the fuser out just look in the area where the large connector is. It is a very small fuse similar to a resistor, green, and is encased in shrink wrap.
The Transfer belt fuse is behind a small black cover. If you pull the transfer belt unit out of the machine about 6 inches, it is located on the front right corner. In other words standing in front of the copier with the belt unit partially out it is on the corner closest to you. You have to remove a screw, a c-clip, a small metal plate and the small black cover is held on with a very small phillips screw.
He is the parts availablitity and part number info.
Fuses are available at http://www.digikey.com/
Transfer Belts
Replace glass fuse 80ma , counter resets automatically.
Item # 507-1218-ND
Fuser Units
Fuse is wrapped in shrink wrap. Cut it out and splice in a 1/16 ma fuse.
Item # F2307-ND
Good Luck and Thank You for using Fixya.
SOLVED
Change Fuse.: fuse is on the front left side((behind a plastic plate), change for 63mA and it will reset. Is for Konica Minolta Bizhub Fuser and Transfer belt reset fuse's for C200 C203 C253 C353 C250 C252 C300 C352 C350 C351 C450 C451 C550 C650 C452 C552 C652 will save $ 250,=
