Replace the fusing unit
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
SOURCE: Printing accurate colors from Corel draw to the Minolta Bizhub C252
HI there i have the same printer and for accurate color i follow this steps:
1 - First publicate you work in a pdf file whit high quality
2 - Go into adobe Acrobat (profesional not reader only) and pres print
3 - Then you have to select in advanced settings and select icc profile "sRGB ..."
4 - You´ll notice that the colors are very real. No oversaturated and the real deal are the fonts that prints correctly in border even if they are very small (- 6 pt.).
5 - RECOMENDATION: For intense black use a compost one 100% in every color or select in the color palette the one at the end of the palette
Greetins.
Nolasco from argentina - DPI Grafica
SOURCE: minolta bizhub erorr codeco202
CO202 relates to tray 1 (top tray). It hasn't managed to lift the paper successfully.
Open the tray, remove the paper, reset the machine (open/shut front door) then reload the paper and try again
Hope that helps
Regards
Taminol
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
