A
Anonymous Posted on Jan 24, 2014
8650 p21 p6 - Konica Minolta Office Equipment & Supplies
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on May 22, 2016
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1914028
Points
11960
P 6 cyan image unit replace
p 21 Color registration problem is P 21. Need to do a color registration procedure.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
My machine bizhub c451 display error code p6,p7, p9,p16, p21
Registration errors. Have tech come out clean IDC sensors and replace black i/u
1helpful
Where in florida can I get a malber p21 washer and get the dementions of it. I have one in NY and love it
A Malber P21 has the following dimensions:
Height:33 1/2"
Width:23 1/2"
Depth:20 7/8"
(From the AJ Madison Web Site)
The model is discontinued, though.
http://www.ajmadison.com/cgi-bin/ajmadison/P21.html
The current model is the P31.
It's an Italian model sold primarily in the New York area.
You may want to call Malber at 516.323.5299. or email [email protected].
I have konica minolta bizhub c550,it showing me P21 and P6,what is the causes?and the black is not printing well
P6 : cyan image unit problem. P21 come after P6, and it's also too a cyan unit image problem. replace the cyan image unit.
What is the causes of p21 and p6 in konica minolta bizhub c550
replace the black image unit and clean sensors under the transfer belt
Nintendo ds lite p6 connector installation instructions. I've tried 5 times and failed.
desloder old P6
tin 4 pads at rear of P6 location on Mobo
add solder to one tab ( holding tab)
place p6 in position
tack in place amking sure conductors of P6 are inline with the solder tabs
tack up other holding tab
with a CLEAN iron touch each connector of the P6 into the tinned conductor on the board - do NOT try and add solder or you'll just bridge the 0.5mm gaps!
DONE
or get it done at www.dsdoctor.co.uk
2answers
Malber P21 works 3 times slower than normal; I am afraid it will just stop.
I have a Malber P21 the door was open and not turned on and it filled with water till it overflowed onto floor....any ideas?
Importing MSP Files into P6
There is a simple solution to import mpp files into P6.
Please contact me.
[email protected]
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
