Sir i replace black developer and i made the gradation also even it is showing c2558 and also the tones is not getting into the developer unit
Did you replace the developer or did you replace the developer unit and developer????? Of course you replaced the entire unit right????? Because if you attempted to dump the old developer and add new Its not going to work.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: c2558
Error code relates to an out of range ATDC sensor level detected on the black I.U
It normally happens when customer does not replace the toner when prompted.
It can usually be cleared by opening and closing the front or right side covers thus allowing the machine to cycle and add toner until it reaches an acceptable level.
If not cleared after four or five attempts go into service mode and run tcr toner supply for black.(In Image Adjustment)
This will clear down the error
Or you may need to replace the black IU if that doesnt work.
