Konica Minolta bizhub 250 All-In-One Laser Printer Logo
A
Anonymous Posted on Nov 06, 2013
Konica minolta C252 not found on server - Konica Minolta bizhub 250 All-In-One Laser Printer
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Apr 03, 2020
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1914097
Points
11960
Load the proper drivers????? can it be pinged??? is there activity on the leds at the network connection to the copier.
5 Related Answers
copierhell
  • Posted on Dec 20, 2007
SOURCE: konica minolta bizhub C252 printer Problem
Is anyone else having problems getting Konica to stand behind its products.
Anonymous
  • 162 Answers
  • Posted on Nov 21, 2008
SOURCE: lost connexion to windows server
Check if it's online in the Server, o a scan and print. The check the sharing status - is it shared ?
Anonymous
  • 183 Answers
  • Posted on Dec 16, 2008
SOURCE: error code c-5102 in Konica minolta c252
Here’s your GEEK-steer …
This thread appears to cover the solution to your problem related to error "C5102: Main Motor’s failure to turn":
http://www.copytechnet.com/forums/konica-minolta/15515-c252-m1-operation-test.html
In addition, here’s the link to “Bizhub C250P” related support downloads:
http://kmbs.konicaminolta.us/content/support/supporthome.html
Hope this helps, and please post back with a status report and/or any further assistance you might need.
"Today's the best day of my life...and NOW you're part of it!"
Anonymous
  • 3 Answers
  • Posted on Mar 19, 2009
SOURCE: Konica Minolta copier model C252 code C6102 any idea
C6102: Drive Home Sensor malfunction
1.Correct or change the Scanner drive
(cable, pulley, gear, belt) if it is faulty.
2.Correct the Scanner Motor set screw if
loose.
3.Adjust [Image Position Leading Edge] and
[Feed Direction Adjustment].
4.Check the PC201, M201, PWB-IC and
PWB-C connector for proper connection
and correct as necessary.
if all that doesnt work Change PWB-IC.
Anonymous
  • Posted on Apr 02, 2009
SOURCE: Konica Minolta Admin Password
Try 12345678.  That worked for me for my Bizhub C250.
3answers
Konica Minolta BizHub C252 - pale colors on the long side
Konica Minolta BizHub C252 Repair Questions,... - Fixya
www.fixya.com > Forum > Printers & Copiers > Konica Minolta
Konica Minolta BizHub C252 - pale colors on the long side · Konica Minolta. ... I have a Konica C250 machine which cannot print red color at all. I had changed ...
Konica Questions answered here ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/40820
Aug 22, 2008 - On the right hand side of the drum (the part that has the large green handle) that easily slides out. There is a ..... I have konica minolta bizhub c252 colour printer. ... The K light came on a long time ago and is constant on now.
How to clean the drums/i units on the konica minolta number ...
? 0:28
https://www.youtube.com/watch?v=eD8HdNq0MlE
Nov 23, 2011 - Uploaded by Tennants Nottingham
How to clean the drums/i units on the konica minolta number plate printer ... Fix or repair color laser printer with fading, lightprint, or lines samsung clp 300 ... Imaging Unit Reset for Konica Minolta Bizhub C203 / C253 / C353
How to install konika minolta with computer
To get to the network settings: Press the Utility/Counter key, select Administrator Settings, enter 12345678 as the password, then select network settings. You will find all the settings for networking the machine there. The print drivers can be downloaded from Konica's web site: kmbs.konicaminolta.us
User manuals can be found there as well.
What can I do to may Bizhub c252 if the code out in the scree is cd307
It going to require a technician because that code series deals with NVRAM which can only be upgraded or replaced by konicaminolta technician who have access to secure server for firmware upload procedures
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Error c252
no such code for bizhub c252
7helpful
Konica minolta C252 error code C9401
my machine konica minolta C252 is giving the code 9401 how should I resolve and what is
Lost connexion to windows server
4helpful
3answers
Konica minolta bizhub C252 printer Problem
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
