20 Most Recent U-Line Wine Captain (2015WC) Wine Cooler Questions & Answers
ULine U-2115WCS Wine Fridge flashing "ER" after temp.
Question edited for clarity. Question moved to a better category.. The Thermistor has failed or is failing. It is the temperature sensor that is basically your electronic thermostat. Troubleshooting Guide: U-Line Refrigerator Error Codes U-Line refrigerator troubleshooting begins with cracking the codes. Let's take a look at U-Line brand error codes.
Error Code ER
Diagnosis: Thermistor 1 is open Explanation: The U-Line refrigerator error code ER is alerting you to a failed thermistor. Thermistors are used for various temperature readings. These provide reliable temperature readings using a resistance which varies based on surrounding temperatures. If you have a U-Line wine cooler, for example, it will include ambient temperature surrounding the refrigerator unit. If the thermistor 1 fails, the refrigerator will continue to operate on a preset 10 minutes on and 30 minutes off time interval. Solution: Use an accurate ohm meter to test the thermistor. If the thermistor is defective, have it replaced. https://www.google.com/search?q=uline+u-2115wcs+thermistor ..
4/14/2023 10:39:35 PM • U-Line Wine... • Answered on Apr 14, 2023
0answers
Liimna1995
Be the first to answer 12/29/2015 8:46:27 PM • U-Line Wine... • Posted on Dec 29, 2015Be the first to answer
29 WC stopped working, light & fan works
I think we need a little more information... It could be the thermocouple, the compressor, or the temperature control (less likely).
3/1/2015 4:27:13 AM • U-Line Wine... • Answered on Mar 01, 2015
I can't hear the bass sound on any earphones/headsets while playing music
This may sound silly, but when was the last time you've had your hearing checked? Base + high treble are the 1st to go;
2/14/2015 9:49:01 AM • U-Line Wine... • Answered on Feb 14, 2015
What should six guy like me and want to date me?
Hello Georgia; My name is Peter. I am a retired field service refrigeration technician. I do not know how your question got into this section. Do not take advise from friends or family. No one knows you better than yourself. Yes, talk to people. But, only you can answer this question. You need self confidence. Know what you want. See through the phonies. Bid your time. Maybe none of these guys are for you. You are special and someday, totally unexpected, only one guy will bring you happiness for the rest of your life.. Just an old, happily, married man for 30 years. Married late. But I waited until I knew, my wife was the one. Do not rush. Live to so meaningful when you share it with your true love.
1/16/2015 11:50:38 PM • U-Line Wine... • Answered on Jan 16, 2015
Door seal is not tight
Hi, The only adjustment on this model is the door itself by adjusting the door hinges. Loosen the top one first and try this one first, if not working enough loosen the bottom one and this should work. Good Luck I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
4/13/2014 3:03:04 PM • U-Line Wine... • Answered on Apr 13, 2014
0answers
0answers
0answers
Wine not cool
Be the first to answer 1/20/2014 3:31:18 AM • U-Line Wine... • Posted on Jan 20, 2014Be the first to answer
0answers
2015wcs-00 not cooling
Check thermostat
12/19/2013 11:43:44 PM • U-Line Wine... • Answered on Dec 19, 2013
I have a U-Line 2015WCB wine cooler that stopped cooling recently. I bought and replaced the thermostat control unit and the wine cooler started up and began cooling, but after an hour or so shut off
sounds like a dirty condenser the compressor will overheat and not turn back on until cooled off
11/22/2013 11:34:33 PM • U-Line Wine... • Answered on Nov 22, 2013
My U-Line mode l15BWC fan and compressor won't work
More than likely it is the temp control (thermostat) it is what controls the on and off
11/22/2013 11:24:25 PM • U-Line Wine... • Answered on Nov 22, 2013
I have a 2 drawer wines cooler, just now
try unplugging for about 5 min. and plug back in
11/22/2013 12:25:59 PM • U-Line Wine... • Answered on Nov 22, 2013
U-Line Wine Captain (2015WC) Wine Cooler Logo
81 questions posted
Top U-Line Refrigerators Experts
Kardoc
Jorgie  the...
Jorgie the...
ADMIN Andrew
ADMIN Andrew
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • U-Line Refrigerators
Most Popular Question
steps replace thermostat uline 2015 wc
  • Refrigerators
