20 Most Recent U-Line Refrigerator Ice Maker Questions & Answers
2answers
U-line bar refrig/icemaker
The fact that the compressor is two years old does not mean it cannot break down again, give more details on the problem to troubleshoot further
4/15/2021 9:52:49 AM • U-Line... • Answered on Apr 15, 2021
U-Line Model WCM48
Sorry for the delay in responding...
Most models have the valve located at the back of the machine on the lower left hand side(viewed from the front). You may have to remove the entire back cover via the hex head screws to get at it. (some models have the valve located behind the front toe kick panel.)
First follow the waterline to determine the location of the valve within the fridge. If it is at the front then the toekick panel will have to be removed. If there are no visible screws then it is most likely a clip on style. If there is a knob for temperature setting then the knob may have to be pulled off first.
If there is a smaller cardboard panel at the bottom rear of the fridge remove it and you should see the valve. If not then remove the entire back cover by removing the screws along the rear perimeter of the fridge. The panel may stick to the back of the fridge but gently pull and it will remove. The valve should now be seen and can be disconnected.
Be sure to unplug the machine first and turn off the water supply. There will still be some pressure in the waterline so have a towel ready.
The valve itself is available online, I think the correct one is located at: http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=832567&PPStack=1
Just be sure to verify that it is the right one before ordering.
12/18/2020 4:14:55 PM • U-Line... • Answered on Dec 18, 2020
I have an U-Line model
the condensate drain pump will shut unit down and only run drain pump if over fill is seen may be noise you are hearing if condensate pump removed has to be wired so kill switch in drain pump is over ridden for gravity drain
11/15/2017 4:29:51 PM • U-Line... • Answered on Nov 15, 2017
ULine 2175RF Digital Touch Controller not responding.
Hi
You will need to remove the grill. Unplug the unit, Then on the control board you will see 4 wire with a black connector. Unplug that and plug it in 4 or 5 times. Make sure you dont bend the pins. Then plug the connector back in and plug unit back in. You should have better response on the display. They have a special coating and the pins needs to be cleaned this way.
9/7/2017 2:28:40 AM • U-Line... • Answered on Sep 07, 2017
How do i get to the fill valve on my ice maker?
Follow the water line to the water connection from the water supply from the home. The valve should have two wires connected to it and will likely be behind a removable panel.
12/6/2014 8:10:06 PM • U-Line... • Answered on Dec 06, 2014
Freezer works not making ice water works also
You could have a stuck closed water control valve, timer issue or the tray full lever/bail is in the up position.
12/6/2014 8:07:16 PM • U-Line... • Answered on Dec 06, 2014
Refrigerator want turn on
Hard to say but I would start by checking the thermostat.
5/12/2014 4:51:54 PM • U-Line... • Answered on May 12, 2014
I have a Uline CLR 2160 ice maker. I am trying to
Your display will only show ice or off. There is no temperature settings.Now when I give the directions to put it into clean make sure the green led above the symbols is on steady. If you hold down the on/off key and hit the light key 3 times then release the on/off key last.(give a 1/2 second delay from releasing on/off key. It should go to CL. If led lights dont comeon then let me know.
4/23/2014 12:04:17 PM • U-Line... • Answered on Apr 23, 2014
0answers
Not making ice
Be the first to answer 3/10/2014 7:55:26 PM • U-Line... • Posted on Mar 10, 2014Be the first to answer
0answers
My Honeywell model 88058 wine chiller quit
Model 88058 Honeywell Wine cooler, my mistake, the capacitor in the upper LEFT corner had bulging rupture disc groves, replaced, with higher voltage, about $1.50, now works great
1/18/2014 5:01:14 PM • U-Line... • Answered on Jan 18, 2014
2answers
HAVE YOU FIXED THE PROBLEM?? i WAS JUST GIVIN THE SAME WINE COOLER WITHT HE SAME PROBLEM
1/18/2014 4:57:48 PM • U-Line... • Answered on Jan 18, 2014
LG LFX25976ST refrigerator water in door but no water to ice maker
Check for 120 V at valve when it is supposed to be filling
11/22/2013 11:06:37 PM • U-Line... • Answered on Nov 22, 2013
Ice is to big
If you pull the cover off the front of the ice maker you will see a little screw in the upper right corner it will have a + and - screw clockwise to the -
11/22/2013 11:03:18 PM • U-Line... • Answered on Nov 22, 2013
Not getting water into trays,water line to unit
Possible water valve needs replaced check to see if you have water up to the valve
11/22/2013 12:27:28 PM • U-Line... • Answered on Nov 22, 2013
U-Line Refrigerator Ice Maker Logo
122 questions posted
Top U-Line Refrigerators Experts
Kardoc
Jorgie  the...
Jorgie the...
ADMIN Andrew
ADMIN Andrew
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • U-Line Refrigerators
Most Popular Question
u line co75fb under counter
  • Refrigerators
