20 Most Recent U-Line 75R Refrigerator Questions & Answers
2answers
ULine 1175BEV door has a weak seal, does not close easily.
Use a good level and ensure that the unit is not tilted forward, it should be tilted to the rear slightly. The side to side should be level.
1/2/2019 3:58:10 PM • U-Line 75R... • Answered on Jan 02, 2019
3answers
Uline 75R refridgerator stopped working
Sounds like you did everything right
3/1/2018 4:24:01 PM • U-Line 75R... • Answered on Mar 01, 2018
Will not get colder than 50
The first thing to check would be the condenser coils. Not sure where it is on your model, but when they collect dust, they do not allow the fridge to cool down correctly. It will be on the back of the fridge. Either running down from top to bottom or will be at the back behind the lower panel. If the condenser fan is running, then the coil is probably dirty. Unless someone has accidentally moved the temperature setting inside the fridge.
2/22/2015 6:42:01 PM • U-Line 75R... • Answered on Feb 22, 2015
Er blinking
check door switch unplug unit 5 sec see if ok
11/22/2013 11:39:36 PM • U-Line 75R... • Answered on Nov 22, 2013
Iwas cleaning refer and punctured the back. I hear air . what to do?
That is not air you have punctured a Freon line and could be expensive to repair depending on where
11/22/2013 12:32:24 PM • U-Line 75R... • Answered on Nov 22, 2013
0answers
Wiring diagram
Be the first to answer 10/16/2013 10:33:23 PM • U-Line 75R... • Posted on Oct 16, 2013Be the first to answer
0answers
manual
0answers
tip
U-Line 75R: Replacing Thermostat when unit will not run
<span>I am reposting <b>Don Willis's</b> EXCELLENT but hard to find tutorial on how to replace a thermostat on a <b>U-line 75R</b> as a HOW-TO Since he spelled "refrigerator" incorrectly (Refidgerator), </span><span>Google cannot find it easily! I followed these instruction and finished in about an hour. </span> <span><br /></span> <span>Got the thermostat part on eBay from a venfor called Part Peddler.</span> <span>The U-Line part number is 2766-S, cost me about $30,shipped.</span> <span><br /></span> <span>Don's post follows, my comments in {} brackets: </span> <span><br /></span> <span>The light worked so it was getting power. </span> <span><br /></span> <span>I used an electrical tester (pencil like device I bought at Lowe's) to figure out that power was making it to the thermostat (black wire) but not after the switch (blue wire). </span> <span><br /></span> <span>To change the thermostat. </span> <span><br /></span> <ol> <li><span>Take covers off the front bottom (one flathead 1/4" hex screw) and back panel (about 10 flathead 1/4" hex screws) of fridge.</span></li> <li><span>Unscrew the old thermostat (2 screws). Leave black and blue wires on it so you will know where to put them on the new one.</span></li> <li><span>Take out glass shelves on inside. Unscrew back panel {note: there are spacers that will fall out} . There are 2 phillips screws {on nuts} that hold the end of the thermometer to back panel. {I removed one and loosened the other to free the "coil" thermostat) reach hand under the back panel and feed the thermometer back through hole and out back of fridge. You will notice a putty like substance that fills in the hole in the back where the thermometer gets fed through. Make sure you keep it to fill in the hole in the back. </span></li> <li><span>Feed new thermometer {coil} end through hole in the back {I found that using a Phillips head screwdriver to guide the coil through was useful} and install to back panel {using those two Philips screws and nuts}. </span></li> <li><span>Put the putty back in the hole from the back to insulate around it. </span></li> <li><span>Feed the electrical end of thermostat through bottom of fridge</span></li> <li><span>Take the wires off the old one and attach to the new one. </span></li> <li><span>Attach the thermostat to its mounting location </span></li> <li><span>Reinstall all the screws in the front and back and you are in business.</span></li></ol><span>Had a hard time finding someone to service it. They wanted $200 to come out to the house + parts and labor. The new thermostat cost $33 at All Brand appliance. I am from Mass and picked it up in Brockton. I emaile dU-line and they sent me the new part number. The allBrandappliance site had the old part number (2766-s) I am notan electrician and this was a few hours work.</span>
0answers
U-Line 75R Refrigerator Logo
59 questions posted
Top U-Line Refrigerators Experts
Kardoc
Jorgie  the...
Jorgie the...
ADMIN Andrew
ADMIN Andrew
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • U-Line Refrigerators
Most Popular Question
running but not very cold
  • Refrigerators
