20 Most Recent
U-Line ?chelon 2175RB-00 Questions & Answers
I have U-line Model #75RB-00 Refrigerator, the
If your motor and compressor isnt running then replace the control. If the compressor tries to run but kicks out then you need to replace the fan. You can always bypass the thermostat to check everything before you guess at it.
My uline refrigerator won't get cold at all. Was
If the refrigeration motor is running and it is not getting cold then it probably is low on freon the gas that is used for refrigeration. Also if the motor only runs for a few minutes then stops it is possible that the cold control is bad, This is a common problem in refrigerators and can be fixed by replacing the control. First you must determine that the motor is in fact running. If the motor is running the motor should feel warm to the touch after 10 to 20 minutes of operation, and you should feel some cooling in the refrigerator on the cooling or evaporator coil. If the motor is running and getting warm or hot and you feel no or very little cooling then it is in fact ether low on freon or a component in the refrigeration system is malfunctioning. Freon can only be replaced by a certified technician.
My Uline ? Model U-217RS-O is 14 months old. The
Ok On the display hold the up arrow for 5 seconds then let go. It will tell you the temperature. Do you have and er at the display? Is the unit outside? What is the temperature(ambient) around the unit? If you hold the up and down arrows together for 5 seconds then release it will show you thermistor temperature for 2,3, and 4 You should only get 2 to give a temperature. 1=refrigerator temp and 2=evaporator temp.
Make sure the condenser is clean from dust.
U-Line 2175RS
The sound you are hearing is the open door alarm. Make sure your door is able to close completely. If you have installed panels make sure they are aligned properly on the door and not getting caught up on the cabinets beside the unit.
