20 Most Recent
Samsung HLN567W 56" Rear Projection HDTV Questions & Answers
I have a samsung
Bad Color Wheel, Common Problem with these sets.. Samsung Parts.com 1-800-627-4368
Encompass Parts Distribution 1-800-638-3328
I have a HLN567WX 56in
Problem could to be the DMD Board,if picture freezes and you still have sound, On the Inside of the DMD board resolder the rectangler Ics on the short side.This has fixed some of the TVs that do this.
Heres another thing Have you Pull the Lamp and Looked inside to see if the Color Wheel is Ok? Pull Lamp out Then turn Tv on watch inside to see if color wheel turns it could shattered causing this.
Samsung DLP has no sound for about 8 minutes when
Mine does the same thing. It makes a regular popping sound that does not change in level with the volume control. When the popping starts getting erratic the pixelated sound starts and in a short time the sound straightens out for the rest of the viewing time. However, the next time the cycle repeats itself. Did you find a fix?
Replace colour wheel because of a high pitch
If you had a pix before just a niosy color wheel then I would double check and make sure you have the right one for that engine. Next, re check all your connections. I hope you have the lamp door in place?
