20 Most Recent Samsung HLP4663W 46" Rear Projection HDTV Questions & Answers
White spots have appeared on my tv after years of
The DLP chip is failing in your machine and will have to be replaced. Samsung use to cover this problem under their "white dot warranty" but I have not dealt with samsung in a while. You can call 1-800-samsung to find ou if it is still covered.
11/26/2019 12:23:44 PM • Samsung HLP4663W... • Answered on Nov 26, 2019
3answers
Samsung HLP4663W Color Wheel
 The color wheel that goes in an HLP4663WX/XAA is:
  BP96-00674A
 This is the correct color wheel.
11/18/2019 10:47:02 AM • Samsung HLP4663W... • Answered on Nov 18, 2019
My Samsung HLP 4663wx makes a loud humming noise.
it is probably the color wheel going out. this is something a technician should do. can call 1-800-samsung or go to samsung.com for nearest service center.
7/1/2019 9:56:20 AM • Samsung HLP4663W... • Answered on Jul 01, 2019
Our 50
I would have the Power Supply board and the Ballast replaced. Samsung recommends replacing both these items together. You can call 1-800-samsung to find the nearest authorized service center.
6/20/2019 12:56:44 AM • Samsung HLP4663W... • Answered on Jun 20, 2019
Samsung hdtv scrfeen half black half res
Sounds like the color wheel is not turning properly. I would recommend calling 1-800-samsung to set up repair with an authorized service center. I would not try to replace it yourself. The part costs $120.00- $180.00.
1/23/2019 8:00:09 PM • Samsung HLP4663W... • Answered on Jan 23, 2019
0answers
Acer AL2002W Buzzing sound
If it is new then return for replacement as it is a screen fault
9/12/2017 8:04:39 AM • Samsung HLP4663W... • Answered on Sep 12, 2017
0answers
Tv went blirry the screen went black and does not switch on
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.... http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/
3/14/2016 7:18:28 PM • Samsung HLP4663W... • Answered on Mar 14, 2016
3answers
HLP 4663WX/XAA
sounds like the color wheel has gone out
2/2/2015 1:59:24 AM • Samsung HLP4663W... • Answered on Feb 02, 2015
Picture looks 3d how do i fix
If you can access the three projector lenses you will probably find them covered in dust, this shifts the light slightly giving a blurry 3D effect on the screen. Clean the dust off with lens tissue and window cleaner or a cleaner made for glasses and this will restore your picture.
9/8/2014 2:20:17 AM • Samsung HLP4663W... • Answered on Sep 08, 2014
I have white lines on my picture screen.
Sounds like light engine or DMD board is going out. Is it on all inputs? when did it start doing; after a move, part being replaced, power outage etc? Does the menu screen have the same issue?
6/23/2014 8:24:40 AM • Samsung HLP4663W... • Answered on Jun 23, 2014
Samsung hlp4663 stand by light
I recently had this issue on my Samsung HL-R4667W. Did the new lamp (phillips) but it still wouldn't light up and was flashing the lamp light and then stanby. I started to remove the rear covers of the TV thinking maybe the wheel or ballast finally gave out. After removing the lower cover I noticed a wire hanging at a unusual angle from a circuit board. I touched it and it fell off. Traced the wire back to the main control board and found that it was a ground wire. I re-soldered it to the board and the TV fired right up. My other lamp was fine too. I hadn't moved the TV in 4 years and only once since I bought it in 2006 so I can't think of anything that would cause it to come loose short of bad soldering from the assembly line. That was a year ago and it works fine still.
4/2/2014 10:48:19 AM • Samsung HLP4663W... • Answered on Apr 02, 2014
0answers
Samsung HLP4663W 46" Rear Projection HDTV Logo
496 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
HL Samsung
  • HL Samsung
Most Popular Question
white spots appeared tv after years
  • Televison & Video
