I have Washing machine AEG L74850 Error code EFO = Anti-flooding system has activated. How do I reset it....?
Tip washing machine towards you, water in bottom of machine will pour out, so be ready! Should work after that, mine did!
Thanks a lot, this worked for my washing machine too.
Saved my day :-)
Brilliant !!! I checked the pipes etc and nothing worked until I read your tip - Tipped the washing machine forward, water came out allowing the float switch to reset and all works fine now ! Thank you very much for sharing the advice,
It happend already like 3 years ago and againh today. I did your trick and it is running.God bless internet advisement.
Hey!
Thanks for sharing. I've just tipped mine as well, and it looks like it's working again.
Happy new year! :o)
JHI, Denmark
Thanks a lot, good bless internet advisement.
In my case it helped only for 10min, then err code appeared again.
Is it reasonable co call service or can I help myself?
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
anti flooding system on
