20 Most Recent
AEG Lavamat 12710 Front Load Washer / Dryer Questions & Answers
I have an AEG Lavamat
You have a leak in the machine and water is accumulating in the base pan. Most likely this leak is a manufacturing issue or a transportation issue. Check to see where the leak is coming from under the machine. If in warranty call the dealer.
Lavamat 12843 no power
Maybe a bit late by now noting your question date.. If you have L & N from supply through suppressor to pcb it could be board u/s but well worth checking for low insulation on elements as oddly this can cause the display not to light!. If you don't have a suitable meter disconnect all wires to elements and see if it works.
Hole in plastic outer drum
I have plastic welded my son's hockey skate with an automotive bumper cover welder and surprisingly it has held up-its basicly like a soldiering iron with a dime size foot on it-it came with a universal welding sticks that have kevlar fibers in it-I would back up the repair area with 3m aluminum repair tape and fill in your hole-cheers Denyy
AEG Lavamat Turbo 12710 update. Machine is AEG Lavamat Turbo 12710 update. Machine is refusing to start on any program. I set program. Instrument panel lights up as expected. Time indicator starts t
test the following steps and fix it. God bless you
If the washer won't start, the user control and display board may be defective. Check for power to the washer first.If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.If the washer won't start the line fuse might have blown.If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their designIf the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
You will need to change the carbon brushes in the motor. Tip machine 45 deg backwards you might need someone to hold for you and look at motor underneath you will see 2 black carbon brushes remove these and replace if worn then retry machine also make sure the wires to the motor are ok.
