20 Most Recent AEG Lavamat W1050 Front Load Washer Questions & Answers
you may need to replace the shock Absorber on the machine. Check and see if it is broken and working.
AEG Lavamat... | Answered on Feb 02, 2018
5 bar is a good pressure. worth while to check the valve filter as suggested. turn off water, remove hoses from machine. look down valve spigot and there is a mesh filter inset. remove with small pliers and clean
AEG Lavamat... | Answered on Jul 17, 2015
Check your exit hose spigot, it may be clogged. This is if your filter is all clean(ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
(Companies just want you to dump the machine & buy another, its keeps them in business)
AEG Lavamat... | Answered on Sep 29, 2014
Filter is blocked, front bottom left open panel and clean filter but watch there is water in there,
AEG Lavamat... | Answered on Sep 02, 2014
These screws should NOT be adjusted. :)
AEG Lavamat... | Answered on Oct 15, 2013
the module that controls the agitation is not working or not getting the start signal. Have an appliance electrician check it out.
AEG Lavamat... | Answered on Aug 10, 2013
AEG Lavamat W1050 Front Load Washer Logo
75 questions posted
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
sami
Level 1 Expert
Vincent G
Vincent G
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • AEG Washing Machines
Most Popular Question
machine doesn 39 t complete full cycle
  • Washing Machines
