Washing Machines Logo
S
Sharon Trudo Posted on Jan 21, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am trying to replace the lid switch on a Kitchenaid Model KAW750JQ4. How do I get the top off to access the switch?
We are trying to get access to the lid switch
john mabry
Level 3:
Master:
  • Master 413 Answers
  • Posted on Jan 21, 2015
john mabry
Master
Level 3:
Master:
Answers
413
Questions
0
Helped
116519
Points
1185
Check this link: http://www.repairclinic.com/PartDetail/b121p11/Kitchenaid-Washing-Machine-Repair-Manual/4313896/1170635?ss=a11b121-x6b61773735306a7134&mr=0
It fills with water then shut off. So if we hit the lid a few times and turn the dial our selfs it will kick back on.
The most likely failure is the lid switch. It can be found as item 11 here:
for model LSQ9564J (Q0)
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=257590
UNIT UN-PLUGGED
To gain access to the lid switch you lift the top by releasing the spring lips with a putty knife. The are about 4 inches in from the front corners. Press in and lift the top from the center front of the tub access. You have to release both clips to lift the top. Then
lift it straight up pivoting from rear.
Then it is a matter of removing the lid switch mounting screws, disconnecting the connector and replacing the switch.
Closer view of replacement switch:
http://www.appliancepartspros.com/part_details.aspx?part_id=3100003
This should get things back to normal. I would use a meter and check for continuity on the old switch before ordering a replacement. The old switch could just have been loose or the lid switch actuation tab bent down too far. (Lift it up and test lid)
Thanks for choosing FixYa
Kelly
tip
How to fix your washer if it does not drain or spin
kenmore whirlpool,roper,kitchenaid,estate,inglis washer if it will not drain or spin,it's a bad lid switch,remove the 2 head screws,flip the top up,pop the 2 spring clip,unplug the lid switch,pull the cabinet off,remove the 2 screws under the lid,replace switch,put everything back together and your done,most times the model number is under the washer lid-mike
on Jan 31, 2010 • Washing Machines
1helpful
KITCHENAID KAW750JQ4: WASHES FINE, WILL NOT DRAIN AND SPIN. IS THIS THE LID SWITCH OR SOMETHING ELSE?
If this a Whirlpool manufactured top loader, the most common cause of the problem you just described is a lid switch malfunction or lid strike (actuator) problem. Symptoms may include, filling and stopping on the intial fill cycle, stopping right after the wash cycle, not advancing to rinse or spin cycles, and a wash tub that will not drain.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike" or "Actuator") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because it does NOT have a lid strike (actuator) and the small hole on the right hand side of the wash tub will not be present. This type of switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator rod by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
repairclinic.com
If the model number is correct, the lid switch part number is 8054980 and costs about $20. The switch is located under the top panel adjacent to the right lid hinge. The hinge will have a rod that acts as the actuator.
If you have questions, or need additional assistance, please post back and let me know. This is a very simple repair that you can easily perform without the assistance of a repairman.
If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20.
Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful to you.
How do you take the top lid off of kitchenaid washing machine model # KAWS777EQUO and replace lid switch?
There are two clamps under the control console. About 1 inch from the edge on both sides. Use a putty knife and slide under to be able to lift console up and tilt back. UNPLUG washer and you will see 1 gold clamp on each side and use a screw driver and pop them out. You will also see a little white quick connect unplug it and til your entire cabinet forward. You can take the entire cabinet off and access the lid switch. When you put the cabinet back on make sure the sides align and u dont crimp the clear hose where the cabinet indents in. Make sure to reconnect your lid switch and put gold clamps back.
How to remove washer top for broken lid switch access
if it is a top loader,,,remove the screws in each end of the control panel,,,some units you have to remove the end caps to access the screws,,,then pull slightly forward on the panel and flip it back it is on hinges,,,,then remove the 2 clips that hold the back to the base,,,unplug the lid switch,,then open the lid and grab the inner lid section and pull the rear of the base towards you slightly and lift off the base,,,, then you can access the lid switch and replace it ,,,,
Wont spin...
Try the video on replacing the lid switch. It's a different model but disassembly is the same. www.appliancehelponline.com/servicemanual.html this will walk you thru
Replace lid switch assembly kaws850
The following link explains how to replace a lid switch:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
On the particular model you have listed, the lid switch should be located under the console near the right rear lid hinge.
You will need to use the steps in the link provided to remove the exterior case to access the switch to see how the actuator and lid hinge interface. You washer is manufactured by Whirlpool and uses Whirlpool parts, so these instructions will apply.
This is a very simple repair, but if you have any questions along the way, please let me know. I hope this is helpful to you.
NOTE: If you have not pruchased a new lid switch yet, the part number is 8054980. It can be purchased at appliancepartspros.com for about $18.
Replace lid switch
You will need to not only remove the control panel, but you will also need to remove the washer casing from the frame in order to acces the switch. It sounds intimidating, but really isn't that difficult to do. The following link explains how to replace a lid switch:
Your washer is manufactured by Whirpool, so these instructions will apply. Most commonly, the lid switch is located under the washer casing along the right hand side of the lid. If the model number you have this listed under is correct, your switch is under the washer casing near the right lid hinge. The mounting screw(s) and ground connector are under the operator console. For clarification, you can refer to pcappliancerepair.com for some excellent exploded view diagrams to assist you. The lid switch is located under the "Top and Cabinet Parts" heading.
If you have any questions about this repair, or need additional assistance, please let me know.
Source for replacement parts?
The lid gasket is not available as a separate piece - an entire lid would have to be purchased. Kitchenaid still has inventory on replacement lids. If you'd like to order, you may call Kitchenaid Customer Service. Their toll-free telephone number is:
1.800.541.6390.
If you would prefer, you may also try MENDINGSHED.COM. They carry a large inventory of Kitchenaid parts, even if the model is out of manufacture.
Top KitchenAid Washing Machines Experts
Paul Bade
ADMIN Andrew
ADMIN Andrew
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
