SOURCE: Samsung DVD-V$357 recorded dvds won't play on other machines
Did you finalize the disk? If not, this should solve your problem. When the disk is finalized you should be able to play it on your computer if you can play other DVDs on it. Some other DVD players can only play specific disks (i.e. DVD-R, DVD+R). This may be another problem.
pjrsop
SOURCE: Samsung DVD-V4600A Combo DVD / VCR will no longer timer record to Videotape
Storms tend to fry most delicate electronics. Quality surge protection is required.
Ben
SOURCE: How to Record TV Programs w/o Cable Box/Satellite Receiver?
if there are rca ports on the front of the vcr which are output, connect those to the tv input 3, the input to input connection is definitely not going to work...
SOURCE: Dvds recorded on Samsung will ONLY play on Samsung
Have you finalised the disc before trying to play it elsewhere? If not this could well be the problem. The option is the menu.
Hope this helps
SOURCE: Can't switch from AV2 to AV1 with Samsung DVD-VR375 DVD Recorder / VCR Combo
To be able to select AV1, you have to first go into the setup menu and set the control set top box setting to OFF. I think you go to the menu >> setup >> features >> set top box control >> select OFF. Note that this has the side effect of erasing any previously stored timer settings.
