Hotpoint Aquarius WF000 Front Load Washer Logo
Posted on Oct 11, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hotpoint WF000P, On/Off light and Energy Save lights start flashing and sounds like the pump comes on at the same time - only way to stop it is to switch off at mains. Machines washes, rinses and spins but clothes still very wet when cycle finishes however if I put them back on just to spin it seems to work OK. Any suggestions on what problem is?
bernard miller
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 121 Answers
  • Posted on Oct 11, 2017
bernard miller
Expert
Level 2:
New Friend:
Greenhorn:
Answers
121
Questions
0
Helped
39425
Points
346
Your filter is partially blocked
5 Related Answers
Anonymous
  • 96 Answers
  • Posted on Feb 17, 2008
SOURCE: does not spin and rinse properly
Sounds like motor is not coming up to spin speed. May be overheating, in which case you would need a new motor.
Anonymous
  • Posted on Jan 22, 2009
SOURCE: Hotpoint WT540 1400 spin. Flashing Rinse hold and Mini load LED
Had exactly the same last week - Jan 09 - and had to call out Hotpoint engineer - £99.98 all inclusive of parts - it was the main controller board, so thats under guarantee for another 12 months. all working and spinning as should be and only took around 30mins.GS :)
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Nov 24, 2009
SOURCE: Hotpoint WD63 not spinning correctly
Two things to check.
Remove rear cover.
Remove large black hose onto drum
Remove and clean filter inside hose.
Next--remove top cover and check the brushes in the motor, if they are less than 3 or 4 mm long, then replace them.
Please rate my solution.
Thanks.
freetek
Steve Allison
  • 5569 Answers
  • Posted on May 25, 2010
SOURCE: washing covered in dirty marks
It sounds as if a bearing seal was defective when it left the factory and is allowing lubricant to bleed out; I would consider this a warranty item and if the company doesn't care to make it right, file a complaint with the local BBB relating to the dealer where you bought it and nationally against the company itself.
Maybe they don't want this stain on their reputation but this is another reason to avoid US manufacturers.
Testimonial: "Thankyou for your helpful comments."
hotpoint jon
  • 353 Answers
  • Posted on Jun 29, 2010
SOURCE: my hotpoint wml540 is not finishing cycle,the
check your motor carbons
5helpful
The clean light will not stop blinking so the normal cycle will not run
From another link, clean light flashes 7 times. Turn off breaker for dishwasher, wait 5 minutes, turn back on. with dishwasher door open, push high temp, energy save dry, high temp, energy save dry, then close door, open door, press cancel and then Normal wash cycle. Dishwasher Starts!!!!!! Save myself several hundred $. Was about to buy new one from Lowes!!!!!! Thanks everyone!
Hi - reference our washing machine WF000G - the energy save light is flashing along with the on/off button and the machine wont run its cycle - can u help?
Do a search on Google using 'diagnostics, hotpoint, flashing lights'. There must be a manual which will identify what this fault is
7helpful
I've got a hotpoint wf220 wshing machine which is not spinning the pump is working and the on/off lights and mini load lights are flashing
i have a hotpoint wf321 water comes in and pumps out have flashing mini load light on and start light, but drum does not go round,
On and off light and energy save and reduces creases lights flash
Hi Snarey, it sound like your door lock has passed away, you will need to make sure the appliance is unpluged, empty the water out of the drum, and check the vacuum switch which opperates the lock.
Flashing lights on Hotpoint FDW20P Dishwasher
No solution! tried resetting to factory defaults but ended up that even the drain pump stopped working. after flooding the kitchen (nearly). I decided it was terminal and am loking for a new dishwasher urgently as I type. Cheers.
2helpful
3answers
Hotpoint Aqaurius WF000 - Flashing Energy save and on/off switch
check your pump for any blockages it may not be pumping out fast enough the tomer only gives the pump a certain amount of time to pump all the water out if has got some blockage than clean out and this should sort the problem out always check pockets if this is no help let me know and ill let u know what else it could be m8
2answers
Flashing power light
I have just had a mechanic out. I have the same problem. It turns out that the front panel is gone on it. I had it in storage, and it got damp. It is not worth getting fixed, as it will cost about 300 euro!!
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
