Most washers has service manual for technicians inside outer housing shell ,just remove top or front or back panel depend on models and retrieve service manual for technicians and follow the service instruction exactly on the service manual and hope fully if you folow the instruction you will be able to reset your washer
Check out the drain hose and connection hose to pump and then check out the pump in the washer for any clog or junk stock in the pump and clean it with warm water and test it is working properly or replace if it is not and reinstall the pump
In the most front load washer this is very common problem and in these new washers such problems are due to malfunction on the door lock or control panel or control board ,you have to check them all one by one
As you should know most bearing comes with instruction how to install bearings and some you could find instructions on line .
Most likely you need to use special tools or bearing installation and removal tools .
Most likely you could buy them from appliance parts stores or auto parts and major tool stores or online tool stores stores and as you should know there are many different size and shape of bearing tools.
You have to be sure what kind bearing tools exactly you need
Be sure not to damage the bearing and drum when installing and removing old one and installing the new bearing
Change of bearing is a little advance project and over whelming for beginners.
Most bearing comes with instruction how to install bearings and some you could find instructions on line .
Most likely you need to use special tools or bearing installation tools .
Thanks for using FixYa. The filter is located under the panel of front door in the bottom of the machine. You need to pull the panel out and you will find the filter there. Before opening the filter prepare a bowl and a floor cloth to avoid flooding.
Please do rate this solution as FixYa and revert for further assistance.
To find the filter you need to do the following steps. Find your lint trap. Lint traps in washing machines can be in the agitator (the large plastic piece in the center of the tub), at the top of the washer on the rim of the tub, or attached to the washing machine's drainage hose. Pull out the agitator tube to check for the lint trap. Peel any loose lint from the filter. Scrub away lint that doesn't peel off easily with a heavy-duty paper towel or a wet sponge. Feel your way around the top rim of the washing machine's basin. If you locate a trap, pull it straight out of the machine. Peel away loose lint and follow up with a wet sponge or heavy-duty paper towel. Check your machine's drainage hose for an attached lint trap. Remove the trap and peel the top layer of lint off. Rinse the trap in low-pressure, warm water. Reattach to the drainage hose. Check for and remove any lint or debris that may have dropped into the washing machine basin during the cleaning.
Let us know if you want any further clarification.
Thanks for contacting fixya.com
hi i think you mean a ball looks like a ping pong ball it doesent go in pump it sits in filter i allways take them out anyway its up to you strange about water check wires to valves were water pipes fit unplug 1st
Hotpoint Aquarius WF210 Front Load Washer Leaking
This video will show you how to find that leak on any front
loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
