20 Most Recent
Hotpoint Aquarius WF000 Front Load Washer Questions & Answers
My washing machine wont start.
I have a hotpoint washing machine if I start the machine the water it's working after filling up the water the basket doesn't spin
12/29/2021 2:12:38 PM •
Hotpoint...
Answered
on Dec 29, 2021
Water still leaking
Look at and examine the door seal closely for any sign of a hole or tear in it.
If none is visible then it could be the clamp or spring that holds the seal to the drum front that is causing the prob..
Other than that , there could be a crack or hole in the container front.
9/19/2018 1:37:54 PM •
Hotpoint...
Answered
on Sep 19, 2018
Hotpoint wma11 where is the filter?
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Power off the mains. The
filter is located behind the silver plate at the back of the machine at the
bottom. Four screws hold it on. Drain out all the water. The filter is inside
the big black rubber hose attached between the pump and the main drum. Remove
the plastic clip holding it to the pump unit and then the metal cir clip
holding it to the main drum. Inside is a white molded cone and a big white ball
which floats. You will find a lot of junk here, clean out thoroughly. To refit
put white cone back inside just as you found it, at the bottom, fit ball back
into the cone. Attach to the bottom to the drum and re-fasten the cir clip.
Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
7/17/2016 9:49:07 AM •
Hotpoint...
Answered
on Jul 17, 2016
How do I remove the clips from the pump
I found it easier to hold one part with a Pointy nosed pliers and push the plastic grip out the side of the clip.
As it is plastic it just ratchets back into place.
10/18/2014 11:05:50 PM •
Hotpoint...
Answered
on Oct 18, 2014
Hotpoint not drying clothes
Check the vent hose and the vent in the house for dryer lint. Excessive amounts will block airflow and the dryer senses that and shuts off the heat to prevent a fire.
10/15/2014 6:49:26 AM •
Hotpoint...
Answered
on Oct 15, 2014
SMELLY WASHING MACHINE
A mouldy smell is often a sign of trapped residual water stagnating somewhere in the machine often just inside the door seal at the low point or in the filter.
Providing there is nothing like a old sock trapped in the pump or filter then there is not much you can do other than to dry the door seal and powder dispenser after use.
Please remember to rate this solution.
9/10/2014 8:37:34 PM •
Hotpoint...
Answered
on Sep 10, 2014
My Wf000 door Locked is flashing, machine will not lock?
You can try this.
Switch off the washing machine at the mains, unplug it and leave it unplugged for about 5 minutes.
Plug it back in and see if it will work.
If it doesn't work you may need to buy a new door lock mechanism. The door lock has some electronics which can fail sometimes. You can buy the door lock on the internet for about twenty pounds and can do it yourself if you are fairly handy. There are also videos explaining how to do it on YouTube.
It worked for me.
Good luck
6/17/2014 2:35:31 PM •
Hotpoint...
Answered
on Jun 17, 2014
