Maytag Atlantis MAV6000 Top Load Washer Logo
Posted on Jun 02, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Washing machine will not drain
What ever programme I put my washing through, the machine fills with soapy water and starts the cycle. However it will not drain the soapy water out in order to rinse the clothes. Instead the dial clicks round continously. If I manually select Drain or Spin it will attempt these actions, fail and the dial will then continue to click round. I've drained the machine by removing the front of the pump on the botttom right hand corner. I did find 10p piece lodged in the waste pipe. The pump appears to be whole and the impellor spins when the machine is on Spin Cycle but the the machine still wont drain. Can anyone help me please? my washer will wash but it will not drain
  • ratr Jun 03, 2008
    I am having the same problem. Fills with water but does not drain. Tried spin cycle and only hear clicking noise like it wants to work but slips and clicks and hums.
  • rqd2 Feb 09, 2009
    have same problem but hoses blow out ok no apparent obstructions. All belts seem ok, pump turns freeley.Belts do have easy slack but belt on pump shaft turning. Is it a bad pump? Or could it be something else?
Anonymous
Level 2:
  • Expert 246 Answers
  • Posted on Jun 15, 2008
Anonymous
Expert
Level 2:
Answers
246
Questions
0
Helped
110553
Points
580
Please fill your washer with a very small amount of water, turn it to spin and tilt it back. You should be able to see the belt on the bottom turning your pump. I ask you to verify this because imporper belt tension or a bad thrust bearing can keep it from turning improperly. If it turns freely on this test, Then you have something plugged up. Drain the water out. Next unhook the hose that goes between the tub and the pump at the tub side. You can get sock or other small articals of clothing in there that will prevent draining. If that is clear. It is likely you have had another coin go through your hose that goes between the pump and the wall. They can get quite a ways in there and maytag hoses get smaller right before they end. If you have a coin in this area you will need to work it all of the way back to the pump side of the hose.
1helpful
My Indesit washer model no IWC61651 ECO fills with water but does not do the wash cycle will run for hrs keep filling water but programme never moving
Lynne,
The drain hose for the washing machine is pushed too far down the standpipe causing the water to siphon out of the machine. Look at the diagram below:
-make sure standpipe is at least 18-30inches high
-only push drain hose in 4-6inches
1helpful
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
2answers
My washing machine stopped working in mid-cycle. No agitation is going on and I could not drain it but putting to spin.
Make sure the washer fills with cold water from the beginning of the cycle because most washers have a cold only rinse cycle and if your cold water valve is bad then the machine will stop mid cycle because it cannot fill the washer for the rinse cycle. Secondly, it helps to know which washer you have so please enter more info next time you ask a question. Good luck.
Washer is filled with soapy water and will not drain to finish rest of cycle.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
TAKE THE HOSE OFF ON THE BACK {DISCHARGE HOSE} IF THE WATER FLOWS OUT IT IS THE PUMP MOTOR IF IT DOESN'T THERE IS SOMETHING BLOCKING THE OUTLET, SMALL CLOTHING ITEM
3helpful
The washer will not drain or spin
more than likely the pump needs replacing, first of all remove the outlet drain hose from the the place it discharges and lower it into a bucket,this should allow it to syphon away,you may need to empyt the bucket a few times once the machine is empty you should be able to put it on its spin cycle once it has spun locate and remove the filter to remove any objects or lint, fill machine with warm water and try to drain and spin via the programme,if this do not work fit a new pump
Soon as i set cycle and swich on door light flashes open
hi,
The cycle doesn't advance
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Thanks for your question.
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
